Username Post: 64 283 correct pcv parts        (Topic#226652)
hasktavern
Reg: 02-15-09
09-26-09 04:50 PM - Post#1778730
Hi again, still rebuilding my 283 and another question has come up - it's the standard '64 195 HP 283 w/ Roch. 2-bbl. carb. What is the correct original way to hook up the PCV system? Someone before me, in their infinite wisdom, removed/plugged everything - all I have is the rubber grommet at the rear (with a bolt stuck in it) and the 'can' inside. Are the orig. type parts available still? Thanks for any feedback on this.....
tony1963
Loc: Birmingham AL
Reg: 10-11-08
09-26-09 05:14 PM - Post#1778753
    In response to hasktavern
For 1964, the parts are very much available. There isn't much to it really.
The rubber grommet at the back of the block should be removed as there is typically a steel 90-degree elbow that bolts there with a seal. From there, you run vapor tubing (not heater hose) up to the carburetor base where there is a PCV threaded into the base of the carburetor. If you don't have the steel elbow, you can mount a newer styled PCV into the rubber grommet and then run vapor hose to the carburetor. In the end, it all works the same.
You draw fresh air into the crankcase through the oil filler cap mesh filter.
1964 Chevrolet Impala SS 327 Powerglide (SOLD!)
1981 Ford Granada 3.1 L (200 inline 6) (SOLD!)
1985 Chevrolet Suburban C20 454 Turbo 400
1999 Mercedes E300 (SOLD!)
2008 Mercedes E350
2012 Mercedes S550
hasktavern
Reg: 02-15-09
09-27-09 04:00 PM - Post#1779279
    In response to tony1963
Many thanx Tony for the explanation -- now I see how it worked.....
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
09-29-09 03:25 AM - Post#1780074
The steel elbow Tony speaks of is kind of a unquie item. There is a hole in the center of it for a long (3"?) bolt that screws into the bottom of the hole. I see these on ebay every once in awhile but have also seen them in one of the vendor's catalogs, Ecklands maybe. If you find one make sure to get the screw too. You won't find one at the local hardware store.
Just a side note, the 283 that was in my 62 had that port sealed up with a small freeze plug. It had Edelbrock valve covers with breathers but nothing else, no PCV in the system. There was no circulation in the crankcase and there was ton of sludge built up throughout the engine.
Eric
Execution time: 0.252 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:45 PM
