Username Post: starter not engaging flywheel        (Topic#226155)
busyguy8
busyguy8
Loc: SF Bay Area, CA
Reg: 11-21-04
09-18-09 10:21 PM - Post#1774430
Hey guys, I went to turn the starter tonight just to make sure it would turn, engage, and stop turning when I let go off the key.
Turning the key the whole way seems to turn the starter, but not engage the flywheel. It does stop turning the starter when I release the key.
Is this usually an adjustment issue?
Thanks!
-b
Aquired a '56 2dr hdtp BelAir on 6/9/05!
Link to my pics!
-bill
busyguy8
busyguy8
Reg: 11-21-04
09-18-09 11:07 PM - Post#1774434
    In response to busyguy8
ok, so I got under the car and had the wife turn the key. the starter gear spins, but it does not protude outward to engage the flywheel.
Any thoughts?
Link to my pics!
-bill
09-19-09 12:12 AM - Post#1774441
Usually, that is an indication that the starter drive (the little gear inside the starter nose) has gone bad. Depending on your familiarization with starter maintence/repair, it is a relatively easy part to replace. Of course, it requires removing the starter and removing the nose to replace the starter drive. Otherwise, you need to take it off and have a shop do it that specializes in starter/alternator repair, or, take it to your local auto parts store and exchange it. If it is the ORIGINAL starter to your car, repair it!!!
busyguy8
busyguy8
Reg: 11-21-04
09-19-09 08:38 AM - Post#1774557
that sucks. I bought this starter a couple of years ago from a CT member a new starter. I beleive it's a Powermaster 19000 that can be used for a 153 or 168 tooth flywheel. This was my first time putting power to it, so I had no clue that it may not work.
Are there any other possibities before I take it off?
Link to my pics!
-bill
swbatt
West Coast Show Support
swbatt
Reg: 03-25-01
09-19-09 10:41 AM - Post#1774599
Maybe it's stuck. Try tapping/lightly beating on it. In the olden days we used to short across the solenoid sometimes.
Edited by swbatt on 09-19-09 10:42 AM. Reason for edit: No reason given.
beejay
Deceased Member
beejay
Loc: Pflugerville, Texas
Reg: 06-01-04
09-19-09 11:22 AM - Post#1774619
" I bought this starter a couple of years ago from a CT member a new starter."
Hmmm, Think that might be why he sold it??? Just kidding. A CT member wouldn't dare skru another on a deal!!!
I agree with the hammer, just not a BFH and pounding on the starter. Taps might spring it loose.
Bruce
http://www.picturetrail.com/beejay3/"
drummertom
drummertom
Loc: Durham NC
Reg: 09-03-06
09-19-09 12:07 PM - Post#1774638
Hi BG. I had the same problem with my powermaster starter a while back. I found that the retainer behind the pinion had come off. This fixed it. It may not be this exact one, so I would make sure that will fit your particular starter before you order one, if that is the problem.
www.picturetrail.com/drummertom
"Well my time went so quickly. I went lickety spickley out to my ol' 55"
drummertom
drummertom
Loc: Durham NC
Reg: 09-03-06
09-19-09 12:30 PM - Post#1774647
    In response to drummertom
I stand corrected. The powermasrter catalog shows that starter as a 9 tooth starter. Their p/n is 603.
jeffs55
jeffs55
Loc: Shelby Forest, Tennessee
Reg: 01-05-06
09-19-09 12:31 PM - Post#1774648
Yeah, try the tap, tap trick. If you have a plastic hammer, start with that.
If it don't pop loose, you might try gently prying on the gear (if you can get to it) with a screwdriver to see if it will move out.
If that fails, pull the starter and take it to AutoZone and have them check it out for free.
Jeff
55 Handyman
66 F100 project
32 3 Window Coupe project
1948 Studebaker Champion
1977 Toyota Celica Coupe
2000 Blazer 4X4
My Pics
52chevybob
Reg: 05-27-08
09-19-09 03:30 PM - Post#1774731
    In response to jeffs55
First off, that the starter motor is turning indicates that the solenoid core is moving to the end of its travel. You don't get the motor to turn otherwise!
Since you didn't see the gear move, the other problem will be with the lever bearing has given way and isn't moving the gear out to the ring gear. A starter removal tho to see what it is.
No_Dice
"13 Year" Silver Supporting Member
No_Dice
Loc: San Jose, CA
Reg: 04-23-01
09-19-09 08:22 PM - Post#1774896
    In response to 52chevybob
Hit it with a hammer.
busyguy8
busyguy8
Reg: 11-21-04
09-19-09 08:26 PM - Post#1774898
    In response to No_Dice
ok you guys, just got home from a long day, but decided to hit the starter with a hammer like back in the day, still no luck.
I pull te starter, and try jumping it with my battery charger, but it will not spin at all.. Would this be an appropriate way to check to see if the starter will even engage?
If so, there is a speed shop open for a few hours tomorrow, so I will go buy another.
-bg8
Link to my pics!
-bill
57TOMMY
57TOMMY
Loc: Bay Area , Calif
Reg: 08-19-03
09-19-09 09:12 PM - Post#1774915
Vic Hubbard is open on Sundays
Tommy
Stand up for what is right ,even if you stand alone.
busyguy8
busyguy8
Reg: 11-21-04
09-19-09 09:18 PM - Post#1774920
    In response to 57TOMMY
You hit it on the head, Tommy, that's where I'm going. They are the only local speed shop open, wanna join me in the morning?
Link to my pics!
-bill
57TOMMY
57TOMMY
Reg: 08-19-03
09-19-09 09:30 PM - Post#1774929
Brian is going to call about 10 ish I want to be home or I would go. Stop by on the way home if you like
MilesB
MilesB
Loc: Melbourne, Australia
Reg: 04-17-06
09-19-09 09:47 PM - Post#1774936
I had some problems with a Powermaster. The plunger was popping out the back instead of the front. Not sure why, but I fixed it pretty easy with a bolt to keep the plunger on the right side. That's not your problem, but they are a pretty simple device to take apart and fix if you are used to electrical stuff.
Photobucket
busyguy8
busyguy8
Reg: 11-21-04
09-19-09 11:53 PM - Post#1774970
    In response to MilesB
ok, so I just thought of something. MY battery charger is a low amp slow charger, so I decided to jump the charger straight to the battery, and observed the same thing as when it was mounted. The gear spins, but does not protrude.
I can't help but to think it's some sort of retainer or spring that is broken or come loose.
Link to my pics!
-bill
bagel3856
bagel3856
Loc: Inland Empire CA
Reg: 06-06-01
09-20-09 10:32 AM - Post#1775148
I had to change starters when I bought the ZZ4 crate engine because the old one was not compatible with the new engine. Do you think that might be the issue if you bought a new crate engine?
busyguy8
busyguy8
Reg: 11-21-04
09-20-09 10:37 AM - Post#1775153
ok.ok... this is going to be hard to admit, but if Jeff was able to give himself a Darwin award last week, I guess I can do the same.
After bench testing the starter at home last night, I got an itch to try one more thing around 1am. I went to the garage and realized I had been wiring the starter incorrectly, bypassing the switch fitting on the starter.
So after uninstalling the starter, beating it up, testing it, I finally reinstalled it and wired it up correctly, and it turned the engine over on the first try..
Thanks for all the replies and sorry to sound so stupid!
-bg8
p.s. I am VERY thankful I do not have to purchase another starter
Link to my pics!
-bill
Edited by busyguy8 on 09-20-09 10:38 AM. Reason for edit: No reason given.
chevybow
chevybow
Loc: Monroe Ga. Red Neck Capi...
Reg: 09-03-04
09-20-09 11:33 AM - Post#1775170
yea....
jeffs55
jeffs55
Reg: 01-05-06
09-20-09 04:05 PM - Post#1775286
    In response to chevybow
Good goin' Bill. Persistence pays off.
Jeff
55 Handyman
66 F100 project
2000 Blazer 4X4
My Pics
09-20-09 05:56 PM - Post#1775347
Glad you found the problem, Darwin award or not.
MilesB
MilesB
Reg: 04-17-06
09-20-09 06:41 PM - Post#1775388
    In response to wagonman100
Whew, I was a little worried there.. the Darwin awards are for people who kill themselves doing stupid stuff!
Photobucket
busyguy8
busyguy8
Reg: 11-21-04
09-20-09 06:49 PM - Post#1775398
Thanks guys!
Link to my pics!
-bill
beejay
Deceased Member
beejay
Reg: 06-01-04
09-20-09 07:01 PM - Post#1775405
Glad it was an easy fix fur ya, even if it was frustrating!!!
Bruce
Execution time: 1.162 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:43 PM
