Username Post: 1989 chevy tbi timing        (Topic#224600)
lifted 89 tbi
Loc: dulth
Reg: 08-26-09
08-26-09 12:11 PM - Post#1760876
i have a 89 chevy i just put new distributer what do i time it at
lifted chevy
Edited by lifted 89 tbi on 08-26-09 12:18 PM. Reason for edit: No reason given.
lifted 89 tbi
Loc: dulth
Reg: 08-26-09
08-26-09 12:15 PM - Post#1760878
    In response to lifted 89 tbi
and i already unpluged the wire that goes to the computer
lifted chevy
Chevytech
Chevytech
Reg: 04-25-04
08-26-09 02:41 PM - Post#1760954
What are you working on?
What vehicle? What model?
Which engine?
Do you have a timing light?
lifted 89 tbi
Loc: dulth
Reg: 08-26-09
08-28-09 02:28 AM - Post#1761798
    In response to Chevytech
its a 1989 chevy k1500 350 tbi
I am having trouble getting it to run right i put new.
2 injectors and fuel filter
new distributer
msd street fire coil
cap router
plugs wires
I set the timing at -4 and it seems to run the best but if i plug the EGR in it will idle fine butt as soon as i give it gas it run realy ruff and when i unplug the EGR it seems to have a slite miss or a pop out the tail pipes
lifted chevy
lifted 89 tbi
Loc: dulth
Reg: 08-26-09
08-28-09 02:55 AM - Post#1761801
the reason i put the timing at -4 digrees and not 0 degrees is at -4degrees when i give it a littel bit of gas it shouts right to 0 digrees and i am doing this with the electronic timing wire unpluged.
lifted chevy
Chevytech
Chevytech
Reg: 04-25-04
08-28-09 07:00 AM - Post#1761895
The timing should be set to zero degrees at idle. It should not have to be set at 4 degrees after TDC.
It is normal for the timing to advance when you open the throttle.
Your statements are not real clear to me.
The EGR valve should never open at idle. The EGR solenoid should not supply ANY vacuum to the EGR valve at idle. Test it to see if it does.
It sounds like the vehicle could have an EGR problem.
There are multiple types of EGR valves and to help you test it I need to know which kind of EGR it has.
TBI trucks are generally Negative pressure EGR or Port EGR systems, except California emission 4.3 TBI trucks had Linear EGR valves.
This is a site that has a photo and an illustration about EGR vale numbers which should help you determine which type of valve your vehicle has.
http://shbox.com/1/EGR_ID.jpg
A pop or miss in the exhaust could be caused by mutual induction. Plug wire routing can cause this. The plug wire for cylinder five and cylinder seven, on a Chevrolet, should not be routed right next to each other in a parallel manor. One of the other plug wires should be placed between them, and wires for 5 &7 should cross over each other, one time, approximately half way down the wire.
When you start this truck, will it start and idle without you pushing on the gas pedal at all?
lifted 89 tbi
Loc: dulth
Reg: 08-26-09
08-29-09 10:48 AM - Post#1762577
I set the timing to zero.re routed my plug wires to how you sed to.The EGR assembly plant code,DCP,the part idenifcation number, 17087194,Day of year,1,Buid date code,5-1-0,Shift ID,1,Type of valve,N=negative presure,Im going to replace it.
Could it be a burned valve, or a stuck valve seams like it is smoking out the paqssnger side its dark black smoke.Only when half throttle?[color]
lifted chevy
Chevytech
Chevytech
Reg: 04-25-04
08-29-09 11:21 AM - Post#1762597
Anytime a TBI engine looks like it could be running rich, test the coolant temp sensor because it is one of the criteria used by the ECM to determine how much fuel to inject.
There are specs and instructions in the sticky FAQ area near the top of this message board. If you can’t find them let me know and I will post them again.
Also look at the injectors when it is running and see if the have a nice spray pattern and see if both injectors look to be spraying the same amount of fuel.
Great
It is a negative back pressure EGR valve.
Negative backpressure valves should hold vacuum with the engine off. When the engine is started the valve should bleed vacuum. The slightest pulse of pressure in the exhaust system will modulate recirculation (close the valve at least some). A good test for these is to put a hand vacuum pump on the EGR valve and apply vacuum with the engine off and it should hold vacuum. Leaving the vacuum on it, start the engine, and the valve should close.
Have you checked the ECM for trouble codes?
Edited by Chevytech on 08-29-09 11:35 AM. Reason for edit: Add more
lifted 89 tbi
Loc: dulth
Reg: 08-26-09
08-31-09 02:46 AM - Post#1763600
i put a new intake mainifold on it as well as a new,EGR, it is running better now then when i bought it but. i ajusted the vauls there close butt not right any installation tips or how do i ajust them so they are perfect pleas help.
lifted chevy
Smokey
Senior Site Adminstrator
Smokey
Loc: "Small town USA"
Reg: 12-06-99
09-01-09 02:28 PM - Post#1764574
This thread has been moved to the truck's forum (88-98)
'67 427 Chevy C-10
'79 454 surburban
'89 454 1 ton dually
'03 V-Star 1100
In Memory of CT's Mike McVeigh and Ron Schrapp (aka rons56)
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
09-01-09 09:07 PM - Post#1764804
    In response to Smokey
there are two definitive ways to set valve lash. with the motor running and with the motor not running. With the motor running, it works best to do one side at a time so it doesn't make to much a mess. I would recommend oil deflector clips as well. any part house should have them.
just loosen the cap nut until it starts to tick, then tighten until it stops ticking and add a 1/4 turn more.
with a motor not running you set to TDC and there is a set of cylinders you can adjust and then you turn in over another stroke and to another set. I forget the sequence right now but you loosen the rocker nut and then while spinning the push rod tighten until it just ketches, then add 1/4 turn. I do 1/2 turn on new motors.
98 Silverado k1500 4x4 350
lifted 89 tbi
Loc: dulth
Reg: 08-26-09
09-02-09 07:05 PM - Post#1765341
    In response to 355Cheyenne
K thank i just did it i just got a smokin problem out of the right side of the motor.Do you no what i could do or is there somthing, i could put in my motor.
lifted chevy
Execution time: 0.443 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:13 PM
