Username Post: Why is my starter solenoid sticking?        (Topic#223850)
Chevy65supernova
Reg: 06-26-08
08-16-09 01:03 PM - Post#1754868
I just got my Nova running! But my starter solenoid sticks open for about 3 seconds every time I start it. I have a remote mount solenoid from painless which tells me to just run the starter cable to main lug on starter and have a jumper from the batt term to the S term on the starter and I am good to go. That is also the way the Mad electrical site has it suggested to run. My local starter guy told me not to because it will make the solenoid stay engaged longer. So is he correct is this the problem or is Painless correct?? Or how do you guys run the setup?
08-16-09 03:28 PM - Post#1754979
    In response to Chevy65supernova
It may not be electrical. Do you have enough clearance between the starter and ring gear teeth?
Chevy65supernova
Reg: 06-26-08
08-17-09 06:28 AM - Post#1755321
    In response to acardon
That was my next guess, it not being shimmed properly I see evidence of wear on the flexplate. I see the about 3/4 of each tooth shows a wearing away of the gold anodizing. I have been looking online for a procedure to align starter and flex plate or a how to I know I seen it before but I cannot find it.
monty56
monty56
Reg: 04-26-04
08-17-09 09:04 AM - Post#1755415
FWIW I used a large paper clip as a "Guage" with the starter held in the "engaged" position.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Chevy65supernova
Reg: 06-26-08
08-17-09 02:14 PM - Post#1755622
    In response to monty56
Ok I will try that now this may be a dumb question but How to I keep it in the engaged positions with out turning over and firing the motor or anything?
08-17-09 02:24 PM - Post#1755628
You can use a screwdriver behind the starter gear to pull it into the ring gear.
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
08-20-09 07:13 PM - Post#1757689
Take the solenoid off the starter, then mount the starter back up to the block. You can then pull the bendix and gear out into the flexplate, then measure the gap between the two.
In certain situations, the copper contacts on the inside of the solenoid can have a tendency to weld together. Using the remote solenoid to activate the starter will exacerbate the problem. Try using a quality solenoid (AC Delco) in place of your current solenoid.
Old_Longboarder
Deceased Member RIP Art
Old_Longboarder
08-22-09 11:39 AM - Post#1758499
    In response to Vaughn
Remove the cable from the battery post on the solenoid, touch it to the small solenoid activation terminal, it will throw the drive into the flywheel, but the starter motor won't turn.
Home.., is where dog hair sticks to everything but the dog.
08-30-09 10:44 AM - Post#1763154
to test the remote solenoid just bypass it. an under rated or low amp solenoid can get the points stuck together alot easier than a higher amp rated one. i like at least an 80 amp unit.
08-30-09 11:10 AM - Post#1763172
    In response to bobb
If the solenoid was provided by Painless Wiring I'd hope it would be a good quality one, but you never know anymore. That's one of the products that got sent overseas a loooooooong time ago and it's hard to get really good ones.
Low-end wrecker units that use an electric pump or electric winch setup often utilitize a heavy duty Ford style solenoid as well, and it can be tough finding replacements that are good enough. I see a lot of guys having trouble with theirs not lasting very long.
Execution time: 2.664 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:25 AM
