Username Post: oil leak on an 84 s10 2.8l v6        (Topic#219498)
84 chevy10
Loc: salem new jersey
Reg: 06-08-09
06-18-09 03:14 PM - Post#1719493
i have an oil leak but can not find out where it is coming from i degreased the whole motor and still no luck.p it drips from the back of the motor onto the tranny and then it sprays all over eveything. i powerwashed it all and still cannot find it and is getting really frustrating any help is greatly appreciated thanks timmy
ExtraScrews
Loc: Kansas, USA
Reg: 08-19-04
06-18-09 05:47 PM - Post#1719583
    In response to 84 chevy10
I used to have an 84. It leaked oil from that nifty 2-piece rear main seal. Could that be where yours leaks from?
1995 S10 (4.3 5-speed)
What is your malfunction?
69 SS396
69 SS396
Loc: Lakeland, Fl
Reg: 11-30-08
06-19-09 04:43 AM - Post#1719743
    In response to ExtraScrews
Rear of intake manifold? Oil pressure sender?
The fate of empires depends on the education of youth-Aristotle
Kids will be kids, but parents should be parents.
Sean
http://www.picturetrail.com/myelkyss
1969 El Camino SS396 "Misty Meaner"
84 chevy10
Reg: 06-08-09
06-20-09 05:29 PM - Post#1720499
    In response to 69 SS396
dont can not see anywhere that is leaking on top the motor it starts about 3/4 down the motor i had a guy look at it and told me not to worry about cuz it wasnt and head gasket or anything serious but i am going to find it and fix let you know what i find out
JaVeRo
Loc: East Texas
Reg: 02-02-06
06-20-09 09:55 PM - Post#1720617
I had an 87 2.8 that started leaking around the distributor housing. If I remember right, it had an o-ring seal and below the o-ring was oil under pressure from the oil pump. It was an easy fix after my neighbor told me what the problem was.
James
2003 S10 Blazer 4wd (wife's)
2001 S10 Crew Cab (wife's mail truck)
1996 K1500 (mine)
1979 GMC 3/4 ton 2wd 4spd with a "Gilley's" bumper sticker, my first brand new truck.
2006 K1500 Company Truck
2006 K2500 NV4500 4.10's
Senior Chevytalk Moderator
06-21-09 06:29 PM - Post#1720995
    In response to JaVeRo
I have a similar problem. One day, I'll track it down. I suspect the oil cooler lines. I installed a new lines not too long ago.
LSGarage
Loc: Mechanicsburg, PA
Reg: 06-22-09
06-22-09 04:22 PM - Post#1721507
The valve covers on this engine cover a part of the intake manifold. There is a seam or joint where the intake stops and the head begins. Sometimes this joint is uneven. If you think it is leaking from the valve covers, try to use some RTV at the joints when installing new gaskets. I had this problem on my '86 S-10 2.8 TBI engine.
84 chevy10
Reg: 06-08-09
06-24-09 06:54 PM - Post#1722829
    In response to LSGarage
dude im gettin really mad i cant find this leak i have taken all the vacum lines out and took the carb off and the intake off and nothing
CHVYPWR
CHVYPWR
Loc: Vicksburg, Michigan
Reg: 03-09-01
07-18-09 07:07 AM - Post#1737190
James
This is probably where his leak is. This is a very common place for the 2.8's to leak. It is often mistaken for a rear main leak.
I bought a 2.8 Camaro a few years ago for $200 that the owner thought had a rear main leak. It was the $2 O-ring on the dist, sold that Camaro for $800 after fixing
'52 Chevy convert
'95 S10 4x4
TDS-OF-MN
Loc: Minneapolis, MN USA
Reg: 07-09-01
07-28-09 02:07 PM - Post#1743534
    In response to CHVYPWR
I experienced both the distributor O-ring seal, and the Oil Pressure sending unit leak, on my '88.
When you say it drips from the back of the motor, I'd bet it's probably the O-ring at the distributor. I believe that will only leak when the oil is under pressure, so finding it with the motor off might be difficult.
Good luck!
TomS.
'98 Blazer 4x4, 4dr - stock
'70 Camaro-sold 10-4-08
'88 S-10 Blazer 4x4 (stolen 4-23-06 = recovered as total loss)
'85 1/2ton 4x4 Pickup
305 w/ Quadrajet, 700R4, NP 208, 3.08 gears, Destination A/T's, rust- sold Dec 2014
Chevytech
Chevytech
Reg: 04-25-04
07-28-09 05:33 PM - Post#1743674
If I remember correctly a 1984 2.8 had a rope rear main seal on the crankshaft and they often disintegrated into pieces and would get stuck in the plug up the oil pump pickup screen.
onebrucelee
Reg: 12-16-09
12-16-09 04:59 PM - Post#1825240
    In response to Chevytech
I must say after replacing 3 of these engines and now pulling again for an oil leak again i have found out that these engines form a lip on the crankshaft also known as a wear spot! and when engine heats up the drip will become worse, if the flex plate cover is off it will spray all over while driving. to fix this issue they sell whats called a seal saver which goes onto crankshaft thus giving new seal a nice surface.
ltlvt
Loc: Wichita Falls Texas USA
Reg: 09-17-00
04-27-10 09:18 AM - Post#1905622
    In response to onebrucelee
Mine was the o-ring already mentioned on the distributor.
Runs like a Scalded Dog!!
Execution time: 0.443 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:15 AM
