Hellwig Products IncPerformance Rod & CustomCold-Case Radiators
Octane Lighting
Username Post: 2000 Camaro Cranks But wont start        (Topic#219324)
Supermonkey147
Reg: 06-16-09
06-16-09 01:27 PM - Post#1718201
OK... Every once in a while my camaro will just sit and crank and will not start. I will take the key out, let it sit, try it again and then it might fire up but not all the time i may have to do this several times before it runs. Once it starts its fine and runs great. i thought maybe the chip in my key was bad, so i bypassed that security and it is still doin it,ihave checked fuel u can hear the pump kick on and purge the system and fuel comes out i dont know where to go from here please help!!!
Edited by Supermonkey147 on 06-16-09 01:29 PM. Reason for edit: No reason given.
seawolf18
Loc: South Dakota
Reg: 04-27-09
06-18-09 02:28 AM - Post#1719144
    In response to Supermonkey147
Any codes stored in the computer? Have you checked your fuel pressure?
1980 Chevy K-10 4X4
2001 Monte Carlo SS Daily Driver
89RS98Z28
Reg: 10-14-04
06-18-09 04:42 AM - Post#1719184
    In response to seawolf18
Did the bypass work like it was supposed too? Were you getting the security light? Hows the oil pressure or was it? Got plenty of oil?
Try LS1.com or LS1tech.com......
A lesson learned the hard way is not easily forgoten.
Supermonkey147
Reg: 06-16-09
06-18-09 05:00 AM - Post#1719195
    In response to 89RS98Z28
yes and yes, its getting fuel because we purged it from up front, now what i am wondering is if i have enough fuel pressure, i filled my tank up yesterday, and it has not done it since.... so im thinking... that
89RS98Z28
Reg: 10-14-04
06-19-09 10:22 AM - Post#1719928
Ok, you were getting the security light when not cranking, did the resistor bypass and still not cranking. Is the security light still comming on or no light and still no cranking? If the light is still comming on the bypass is not correct.
Execution time: 0.289 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:56 PM
