Username Post: Need help installing cam bearings        (Topic#218426)
ltlvt
Loc: Wichita Falls Texas USA
Reg: 09-17-00
06-03-09 09:17 PM - Post#1710672
I am installing cam bearings in a 350 small block. It is my first time. i have the tool to do it with but just a couple of questions. The bearings have position 1 2 3 4 5 . I am asuming the front of the engine is #1 position and the rear of the engine is #5. should i install #1 bearing first then #5 #4 #3 #2 or does it really matter. I know i am suppose to align the oil holes in the bearings with the oil holes in the block. Thanks for the help...
Runs like a Scalded Dog!!
motorman
Loc: south western pa.
Reg: 01-25-00
06-03-09 10:33 PM - Post#1710708
    In response to ltlvt
the oil holes should be at the 4:00 o'clock position with the block right side up.
retired race engine builder,former NASCAR tech inspector. new corvettes owned 1959,1962,1963,1964,1965, 1966,1997,1999,2002,2005, 2008 plus 30+ other chevy cars and trucks along the way. 2008 corvette sold and waiting on a C-7.
06-04-09 02:05 AM - Post#1710737
    In response to motorman
yes but that dosent answer the numbering q. i would also assume that the #1 is the front one.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-04-09 07:34 AM - Post#1710861
    In response to bobb
this link should help
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
06-04-09 07:43 AM - Post#1710874
    In response to grumpyvette
That is one of the things I have the machine shop do for me when I have the block machined.
http://photobucket.com/C10Pictures
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
06-04-09 03:46 PM - Post#1711164
    In response to C10 Sleeper
Not a good idea in my opinion.
You cannot clean out the passages with a brush with them in. The block straight from the machine shop is no where near what I call clean. Just my 5ยข.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
06-04-09 06:31 PM - Post#1711274
    In response to fritz1990
Havent had a problem with one yet. The machine shop that does my work is very meticulous and the guy that does all the work spends about twice as long as the other shops I have used. I dont think he would slam a set of new bearings in a nasty block full of shavings.
ltlvt
Reg: 09-17-00
06-06-09 12:25 PM - Post#1712087
I finished installing them yesterday. It is really not that hard of you take your time. I took my time and used the brushes to clean out all the passages. I have a full set of brushes for cleaning blocks. Used some brake cleaner as well as my high pressure washer. First i sprayed the outside of the block with Easy Off oven cleaner to melt all the old grease. After installing the bearings i used a soft insulated peice of copper wire to check the alignment of oil holes in block and bearings. The instructions on the new cam recomend leaving valve covers off whole breaking in the cam to observe if all sixteen pushrods are spinning. I never thot of doing this. I usually have the valve covers on at time of break in. Since I have had 2 cams fail in this block it sure sounds like a good idea to me.I usually pay the machine shop to do it also but now that i am retired a dollar that i don't spend is like a dollar i am paying myself..
thanks for all the help...
motorman
Reg: 01-25-00
06-06-09 12:49 PM - Post#1712098
make sure the cam fits into the bearings before putting the rotating assy in the block. it is no fun to change cam bearing with the rotating assy in the block. been there and had to do that,not fun
ltlvt
Reg: 09-17-00
06-06-09 07:15 PM - Post#1712375
I did that first thing after installing the bearings. I wanted to make sure cam rotated properly before replacing the rear plug behind the rear cam bearing... I will also install the cam before installing the crank when the crank comes back from machine shop. It is a lot easier to insttall the cam with the crank out of the engine..
thanks for the mention tho old as i am gettin i could forget it the next time....
Execution time: 0.396 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:40 AM
