LMC Truck
Username Post: DTC P0200 on 2001 4.3 V6 Blazer        (Topic#210910)
aygl66
Lurker
Loc: Venezuela
Reg: 09-02-07
03-02-09 06:32 AM - Post#1641868
Have a P0200 code scanned on my 2001 4.3 V6 Blazer. Any ideas on how to proceed? What should I do?
LMC Trucks
Senior Chevytalk Moderator
03-03-09 04:19 PM - Post#1643038
    In response to aygl66
You should ask the fuel injection forum. I have no idea what the code means or how to fix it.
SleeperSS
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
03-03-09 08:30 PM - Post#1643256
Here you go...
DTC's
Gchemist...may be worth a sticky..
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
03-03-09 09:05 PM - Post#1643290
    In response to SleeperSS
Sleeper,
I have that link on my favorites. The problem is solutions to DTCs. I have a factory manual to help solve a ton of them. However, my manual skips from P0175 to P0300. GM may have another manual edition for the fuel system. I know Dodge does have several manuals for my old Dakota.
The code above is listed as an Injector Control Circuit Voltage. One site lists the code as an Open Circuit. We know it's electrical. Is the FI spider failing? Is the alternator working properly? What does open circuit mean? How do we fix it?
Post the DTC link in a seperate thread. I'll make it a sticky where we can track a history of the most difficult or common DTCs.
Edited by gchemist on 03-03-09 09:07 PM. Reason for edit: No reason given.
SleeperSS
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
03-03-09 10:09 PM - Post#1643336
P0200
On this particular code, it depends on the 3rd digit of the vin.
'96 S-10 SS
'02 BlaZeR2
aygl66
Lurker
Loc: Venezuela
Reg: 09-02-07
03-04-09 05:17 PM - Post#1643931
Have the alternator and battery checked and both are fine. Try to erase the code again and after a short drive two codes appear on the scanner, being the first P0200 and the second "pd P0200" I really have no clue on where to start!!!
03-10-09 03:58 PM - Post#1648451
Any updates?
aygl66
Lurker
Loc: Venezuela
Reg: 09-02-07
03-11-09 05:16 PM - Post#1649344
Not really, someone sent me a link with a cleaning procedure, but that is it!!!!
LMC Trucks
Execution time: 0.276 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:54 PM
