Username Post: adjusting the idle mixture screws        (Topic#210039)
tamccain
Reg: 02-02-09
02-19-09 12:56 PM - Post#1633727
I need to adjust the idle mixture screws on my quadrajet. The problem is, on the air cleaner it says, "Idle mixture screws are set from the factory and sealed" Because of this, I cannot seem to find these idle mixture screws. It seems like there is some "cap" over them. With that being said, how do I go about adjusting the idle mixture on this carburetor.
1993 K3500
454/4l80e
The Beast
CaptainStompAndSteer
Junior Contributor
Loc: Redding Ca
Reg: 01-29-08
02-19-09 01:13 PM - Post#1633742
    In response to tamccain
You have to dig the epoxy out first. Second of all if you dont know what you are doing you should leave that to someone that is good and I dont mean just someone that can adjust a holley or what ever. I would find someone that knows Q jets to try that. Besides that you should have your ignition timing spot on before you adjust your carb. Just my 2 cents. I know a guy that took his truck to some guy in the sticks for the carb adjustment and his truck has ran really good and it gets really good mileage also.
"May the sun shine in your face and the sparks fly far behind you"
tony1963
Loc: Birmingham AL
Reg: 10-11-08
02-19-09 03:09 PM - Post#1633820
    In response to CaptainStompAndSteer
Whenever I hear of someone wanting to adjust their idle mixture, I always ask for the symptom.
Keep in mind that before touching this, you need to, as mentioned above, make sure that the other engine adjustments are at par.
The idle mixture will only change the air/fuel ratio at idle, not above. Once you open the throttle blades, even a bit, you're running on the size of the openings in the carburetor.
If you find that you must adjust the idle mixtures, the best solution is to start with a rebuild kit. Open it up, clean it out, assemble with new parts. On the base plate of the carb you will find where the mixture screws are leaded over. You can use a saw and cut out around those mixture screws.
To begin, turn them in until they seat, but don't turn hard or you will ruin the screws. Then, back out exactly 2 turns, start 'er up. Turn the screws in until you lose idle speed, then turn them back out 1/2 turn. You're dialed in.
1964 Chevrolet Impala SS 327 Powerglide (SOLD!)
1981 Ford Granada 3.1 L (200 inline 6) (SOLD!)
1985 Chevrolet Suburban C20 454 Turbo 400
1999 Mercedes E300 (SOLD!)
2008 Mercedes E350
2012 Mercedes S550
tamccain
Reg: 02-02-09
02-19-09 03:49 PM - Post#1633851
    In response to tony1963
I have been doing a lot of thinking through all the work I need to do on this truck, so my question was more for my knowledge than anything. BUT, I do have an issue of the truck blowing out black smoke at startup. I am going to replace spark plugs and wires(they look pretty old), and if that doesn't fix it then I may look at a rebuild for the carb.
I am somewhat of a knowledge junkie, so just knowing makes me feel better.
1993 K3500
454/4l80e
The Beast
The_Hunter
The_Hunter
Loc: Manitoba, Canada
Reg: 02-14-05
02-19-09 05:50 PM - Post#1633951
I had that black smoke startup on my truck several years ago. I brought it 2 a local shop since I knew nothing about carbs. All it was was the choke pull off needed to be replaced. I would start by checking your chokes operation.
86 C10 Short Box
Computers are like air conditioners - They can't do their job properly if you open windows.
McLeod
McLeod
Loc: North Carolina
Reg: 01-10-05
02-19-09 07:07 PM - Post#1634012
OK...when turning them back in, do you turn both a little bit, or do you turn one until the idle goes down and then adjust the other? Thanks! Mc
McLeod -- 1999 Tahoe LT, '03 2500HD Ext. Cab.
Junior Contributor
Loc: Redding Ca
Reg: 01-29-08
02-19-09 07:12 PM - Post#1634018
    In response to McLeod
I allways do one at a time turning it in until the motor starts to just run rough and then open it up just a tiny bit past where it starts to smooth out. Then I adjust the other screw the same exact way and never look back. I learned tuning a 327 with a tunnel ram and duall 4160s.
maximus86
Reg: 02-20-09
02-21-09 09:28 AM - Post#1635198
    In response to The_Hunter
When you say "choke pull off" Do you mean the actual choke, or is there something else? I am getting the same symptom.
Chris
Ixonia,WI
1986 GMC High Sierra
2005 Dodge Magnum R/T
A couple motorcycles
A snowmobile
and a boat.
Senior Chevytalk Moderator
02-21-09 09:34 AM - Post#1635202
    In response to maximus86
I tune by carb with a vacuum guage.
http://www.centuryperformance.com/tuning-with-a-va...
Does it work? HMMMM, I can get 19.5 MPG out of my ZZ4 355+ HP!!
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
02-21-09 09:59 PM - Post#1635677
A choke pull off diaphragm is used to pull open the choke when the throttle blades are shifted to wide open throttle while the engine is still cold. It prevents the choke from stalling the motor out.
The choke pull off diaphragm is usually screwed to the outer passenger side of the carb at the top of the air horn, and interacts with the choke linkage. It usually has a large slot in the side of its linkage that the choke rod goes through or connects to.
This diaphragm works the opposite of what most people think of a vacuum diaphragm doing - it starts to operate when there is no intake manifold vacuum (WOT) but shuts off when there is high intake vacuum, like when idling. It is also hooked to a thermostatic vacuum valve, ie. it only works when the motor is cold (and some specific emissions related conditions).
raceman6135
raceman6135
Loc: Calgary, Alberta, Canada
Reg: 11-04-02
02-22-09 08:28 AM - Post#1635791
    In response to Vaughn
maximus86
Reg: 02-20-09
02-22-09 09:40 AM - Post#1635841
    In response to raceman6135
Thanks for all the pics and advice guys! I'm going to fix that and then check all the vacuum lines.
Chris
Ixonia,WI
A snowmobile
and a boat.
RunAndGun
RunAndGun
Loc: Mckinney Texas
Reg: 05-16-09
06-12-09 06:34 AM - Post#1715656
Thank you all for pointing the way for me to adjust my Quad!
Every time I think I have achieved all I can out of my little motor, knowledge I gain from this board proves me wrong.
It runs better than ever now. I am getting ever so slight of what feels like an intermittent miss at low idle, so I think I might need to adjust a little more, but not enough for it to be a priority at present.
I have read many times on this board that adjusting the idle mixture screws only affects the performance at idle. If this is the case, why does my 305 now perform better all the way around?
1984 4WD Short Step Side
305 4Bl Quadrajet, 700R4
Execution time: 0.778 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:02 AM
