Username Post: door adjustment        (Topic#209943)
usmile4
"10th Year Silver Supporting Member
usmile4
Loc: Aurora, Illinois
Reg: 08-12-05
02-18-09 08:42 AM - Post#1632751
I'm trying to align the doors on the 49. The passenger door needs to be raised up at the front of the door. I have the Fischer Body service manual and it looks like I have to remove the door to get to the up and down adjustment at the door pillar. Am I reading this right? Or if anyone has done this without removing the door what are the tricks?
Bill Gommel
2blu52
2blu52
Reg: 03-12-02
02-18-09 12:10 PM - Post#1632879
    In response to usmile4
There are two adjustments, one on the "A" pillar at the hinges, the other is done from the door. The 49/54 shop manual indicates which adjustment to use for up and down and forward or back. I have not read the manual for this information for some time but I never had the idea that the door had to be removed. One thing I have learned over the years is to always without fail take a marker and mark around the hinge plates and the latch plates before moving any thing. With the mark in place you can always return to the starting place. Doors can give the uninitiated fits.
THOMAS JEFFERSON
usmile4
usmile4
Reg: 08-12-05
02-18-09 01:21 PM - Post#1632952
    In response to 2blu52
In the manual it states: Up and down and fore and aft adjustments are provided through oversized attaching bolt holes on the front body hinge pillar. then on one of the adjustments it states: Remove door and at the body pillar adjust the upper hinge....
so I took that to mean if I need to raise the door at the front of the door I need to use the adjustment on the body hinge pillar and therefore need to remove the door.
When I look at the door, the top of the front fender is higher than the edge of the door. I am trying to attach the front body hinge pillar belt weatherstrip and the door needs to be higher to clear the strip.
Bill Gommel
52chevybob
Reg: 05-27-08
02-18-09 02:31 PM - Post#1632996
Basically with the up down adjustment, you need to get eh weight off of the hinges. When you break loose the hinges, the door will be completely free to go up and down and tilt so the best thing is to pull the door. A good shadetree mechanic will just loosen the door bolts and move the door to where he wants it.
usmile4
usmile4
Reg: 08-12-05
02-18-09 02:36 PM - Post#1632999
    In response to 52chevybob
I thought I had to take off the door to get to the bolts. Is it possible to get to the hinge bolts from the inside of the fender by going up from the bottom?
Bill Gommel
2blu52
2blu52
Reg: 03-12-02
02-18-09 05:09 PM - Post#1633118
My apologies, memory must be failing me. At least I can find my way home as yet.
THOMAS JEFFERSON
Bill K.b
Loc: upstate NY
Reg: 10-24-05
02-18-09 09:02 PM - Post#1633319
Here's the deal. Get a floor jack. Use a hole saw to cut a hole in a short piece of 2x4 so it fits on the pad of the jack, or cut a round piece of wood to sit in the cup if it has a large cup. Mount piece of wood to another 2x4 that's the length of the door bottom. Open door, use jack and wood to support door and raise accordingly. Jack should be located towards the hinge end of the door. This should let you take the weight off the door, and because you can raise these jacks a small amount at a time, give you enough control to carefully raise the door as needed.
Doors are a pain in the butt, the ones on my Suburban need work too. Only the right front closes the way it should.
Those who can, do. Those who can't, criticize it on the internet.
1988 G20 van 5.7L - driver.
1993 3500 dually 5.7L NV4500 - tow truck
1991 G20 van - parts truck
Plus cars for swap and sale
&yes, I once tried a frame swap on a 51 Chevy.
02-18-09 11:53 PM - Post#1633414
    In response to Bill K.b
I removed the doors on my '54 Chevy 3/4 ton truck, to weatherstrip them, and never did get them back the way they should have been. BUT... that was before CT. In a few months I'll be reinstalling the doors on my 210, and I have high hopes of getting it done right, and done fairly quickly.
usmile4
usmile4
Reg: 08-12-05
02-19-09 06:31 AM - Post#1633495
You are sounding like I don't need to remove the door so how do I get to the bolts that are on the body pillar underneath the fender?
Bill Gommel
52chevybob
Reg: 05-27-08
02-19-09 10:10 PM - Post#1634138
Aren't those bolts on the inside? If so, you just remove the kick panel.
usmile4
usmile4
Reg: 08-12-05
02-20-09 06:34 AM - Post#1634305
Now that would make lots of sense...I will have to check it out.
Bill Gommel
eplantage
Loc: Southern MN
Reg: 03-15-04
02-20-09 06:39 AM - Post#1634312
There isn't any access to the bolts from inside the '49 kick panel area. Adjustment is made on the door pillar behind the rear edge of the front fender. For moving the door forward or to the rear adjustment is made using these bolts. For moving the door in or out use the bolts that are attached to the door itself, you can remove the check link for better access. Some adjustment can be made using the striker on the door jamb.
Age: 63 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
02-20-09 06:49 AM - Post#1634319
    In response to eplantage
DO YOU HAVE PHOTO OF DOOR SHOT ON CAR SO WE SEE THE GAP.. bill is top rear door real close bottom rear of door big cap if so shim the lower hing at door. you can put floor jack with piece of wood on it slitly jack rear bottom of door when putting shims
Edited by arnieg141 on 02-20-09 06:55 AM. Reason for edit: No reason given.
eplantage
Loc: Southern MN
Reg: 03-15-04
02-20-09 06:55 AM - Post#1634323
    In response to arnieg141
It's easiest to access these bolts with the fender off, although if you remove the bolts at the bottom of the fender you can pry it out and get access from below behind the splash panel. These bolts have a very low profile head on them, (9/16") so what I did was grind a box end wrench so the edge was sharp so the wrench didn't slip off the bolt, then loosen enough to make the adjustment.
usmile4
usmile4
Reg: 08-12-05
02-20-09 02:53 PM - Post#1634661
I'm out of town until the first of the week so I can't get any picture until then. The problem area is on the front of the door where the door and fender corve down from the beltline moulding. The top of the fender is higher than the door at that point. The bottom of the door is very tight to the rocker so I figure I need to move the whole door up to align the front of the door to the top part of the fender. It's hard to explain, so I'll get some pictures the first of the week.
Bill Gommel
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
02-21-09 09:48 PM - Post#1635671
EPLANTAGE has it right. The bolts that you need to get to are under the trailing edge of the fender AND under the rubber dust curtain. Not the best design, but that's the way GM did it. My advice would be to remove the fender to make the adjustment[s]. Then, once you are happy with how everything is adjusted, re-hang the fender. Remember to adjust door WITHOUT the stricker plate attached to the door jamb. Get your gaps right, then replace the striker plate in the appropriate location to get a good closure of the door...follow your manual for this operation. Lastly, re-hang the fender.
1951 Fleetline
RhinoRay
RhinoRay
Loc: Roseburg OR
Reg: 02-27-07
02-23-09 12:05 AM - Post#1636375
    In response to RAM_51
That sounds like a lot of work. I wouldn't attempt to do it without some help putting those fenders back on. I'd be a bit apprehensive to to it myself. There got to be a better way.
RhinoRay
52 Chevy Coupe
Roseburg, OR
Slide Show Of The Project
Intake, Exhaust, Tranny
RAM_51
RAM_51
Reg: 12-28-02
02-24-09 09:22 AM - Post#1637426
    In response to RhinoRay
Actually, re-hanging the fender is the easy part. You can place rags on the inter-fender panel and remove them before bolting the fender on. The tough part is getting AND KEEPING the door where you want it as you tighten the bolts down. A helper might be adviseable for this part of the operation. To repeat, hanging the fender [one in this case] is the easy part of the operation. Of course there is alot of bolt and screw turning to get to the point of dropping the fender [ie, the rocker molding should be removed, along with the front splash apron, and grill should be removed as well]. Yeah, there is some work involved...that was one thing I signed up for when I bought my '51.
1951 Fleetline
Execution time: 3.794 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:42 PM
