Username Post: What is service 4 wheel drive light        (Topic#207379)
ASanders
Lurker
Reg: 01-14-09
01-14-09 05:06 PM - Post#1607055
Have a 2000 suburban 1500 4 wheel drive. Information light in dash shows service four wheel drive what needs to be serviced.
rod0708
Lurker
Reg: 01-14-09
01-14-09 05:52 PM - Post#1607097
    In response to ASanders
my 2003 avalanche had the same light on and i had to replace the 4 wheel drive switches.mine was under warrenty at the time so i dont know what it cost to replace hope this helps rod0708
69 SS396
69 SS396
Loc: Lakeland, Fl
Reg: 11-30-08
01-14-09 09:06 PM - Post#1607270
    In response to rod0708
That message is telling you that your 4wd has a problem. Does the 4wd work? Do you have the buttons on the dash or a stick on the floor? The most common cause that I have seen is the dash switch going bad. Do the lights on the switch flash? If so that is probably it.
The fate of empires depends on the education of youth-Aristotle
Kids will be kids, but parents should be parents.
Sean
http://www.picturetrail.com/myelkyss
1969 El Camino SS396 "Misty Meaner"
AK_02Chevy
AK_02Chevy
Loc: Anchorage, AK
Reg: 02-17-09
02-17-09 03:18 PM - Post#1632268
    In response to 69 SS396
Not sure if your problem has been solved or not, but I just went through the same thing on my 02 Silverado - I swapped out the switches. The first thing I should have checked was the Auto Transfer Case (ATC) fuse - in the electrical center under the hood- that was blown, and it actually set the "Service 4WD" light off. But I hear the switch is a more common problem.
1967AND2002
Loc: Austin, Texas
Reg: 10-10-02
05-22-09 02:00 PM - Post#1702700
    In response to AK_02Chevy
It is a bad solder job on the actuator switch in the dash. Remember the board in the wiper motors in the last generation? Same issue. The solder job was not good enough. You can add solder to the connections in the switch.
Past: 56-210, 60-348conv, 62-ImpSS409, 64-ImpSS327/365, 65Imp, 67CamaroZ, 68&96Corvettes, 71M/Carlo, 74M/Carlo, 75El/CaminoSS, 75Stepside, 94-1500.
Now: 69Corvette, 96-1500, 77-454TrlrSpc, 83K5Blazer, 04z71, 02CamaroZ, 5103JD
67gmc
67gmc
Loc: Farmers Branch, Tx, USA
Reg: 07-08-02
05-22-09 07:07 PM - Post#1702906
    In response to 1967AND2002
I have a 99 suburban that the 4 wheel drive lights work sometime and not other times. I think everything is working properly but I cant stand the lights not working. Could the bad solder joints be the problem on a 99?
Jackie
67 1/2 ton GMC short step
68 1/2 ton Chevy long fleet
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Tahoe
99 1/2 ton Chevy Suburban 4x4
67gmc
67gmc
Reg: 07-08-02
05-22-09 07:08 PM - Post#1702908
    In response to 67gmc
Also, is it hard to remove the switch for repair?
Jackie
CaptainK
CaptainK
Loc: Maryland
Reg: 02-25-02
05-23-09 05:53 AM - Post#1703118
Very easy to remove the switch. Block the wheels on the truck, tilt steering wheel all the way down, move the shifter to the 1 position, pull the dash bezel off and out, pop the couple tabs holding the switch in place, disconnect wiring harness.
'99 Silverado (NBS)
67gmc
67gmc
Reg: 07-08-02
05-23-09 01:14 PM - Post#1703304
    In response to CaptainK
Thank ya much. I have looked on GMParts Direct and cant find the switch. Would anyone happen know the part number?
Jackie
AK_02Chevy
AK_02Chevy
Loc: Anchorage, AK
Reg: 02-17-09
05-25-09 11:42 PM - Post#1704662
try 15709327. I know this part number has been replaced with a newer one, but you should still be able to pull it up by the old one.
plan B - when you pull out your switch, the part number is actually stamped on the back - you should see two rows of numbers, use the bottom row.
Alex
1997 Lumina LS 3.1 (former ride)
2002 Silverado 5.3 Vortec
2002 Express/Chassis 30 Passenger Bus Conversion (work vehicle)
1967AND2002
Loc: Austin, Texas
Reg: 10-10-02
05-27-09 09:02 AM - Post#1705458
Probably so. They do not seem to want to fix little issues unless they are life threatening. My brother worked on the solder wave a for a while at IBM. He is who clued me in on it.
Execution time: 0.446 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:51 PM
