Username Post: TAC module; replace or refurbish        (Topic#205511)
BigSilver
Reg: 06-04-08
12-18-08 10:03 PM - Post#1587956
2003, 2500, Chevy Suburban, 6L
a) Can a TAC module be reprogramed?
If not, can a second hand TAC, from a scrap yard,
be retrofitted to the Suburban?
b) In either replacement scenario,
would the Suburban learn and adapt with the donner TAC?
c) What would be the GM part number for the TAC module?
d) Whats the typical cost for a TAC module?
Reason for the interest in changing the TAC, is that my present unit causes hysteresis to the butterfly movement.
Both the butterfly and accelerator pedal sensor have been replaced, and wiring verified.
Edited by BigSilver on 12-18-08 10:07 PM. Reason for edit: No reason given.
LMC Trucks
Execution time: 0.208 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:19 AM
