Username Post: 230 / 250 into a '49 fleetline        (Topic#201455)
jmschristiansen
Reg: 09-02-08
10-20-08 07:11 PM - Post#1546622
I know that the 230 / 250 / 292 is completely different in mounts, etc from the 216 / 235 / 261, but what is needed to make the swap?
Would like to put a 230 w/powerglide & 10 bolt into my '49 fleetline, am removing it, complete, from a '69 camaro.
Any suggestions?
I know I have seen comments on this before, but have not been able to find them again.
Thanks,
'49 Fleetline Deluxe, in the works, for my teenage sons...
10-20-08 09:59 PM - Post#1546681
    In response to jmschristiansen
This is a very good swap, and we have several members here with one of these engines in their cars.
Depending on your fab skills, you can either make your own engine mounts or get commercial mounts from Langdons.
http://www.stoveboltengineco.com/acartpro/product....
The same goes for the transmission mount. If you don't want to make your own, you can get a bolt-in crossmember from Chassis Engineering.
http://www.chassisengineeringinc.com/
Almost no modification is needed in the engine compartment. Everything clears except the radiator, and there is room to move it far enough forward. You will need to convert the electrical system to 12 volts because there is no stock 6 volt starter which will fit the engine.
Hopefully, one of the members who has done this swap can chime in and maybe post some pics.
jmschristiansen
Reg: 09-02-08
10-22-08 03:13 PM - Post#1547819
Thanks for the comment Ray, hopefully someone else will post some pictures / experience regarding this swap.
I hope to go pick up the drivetrain this weekend.
Thanks for the sites as well, I had seen the Stovebolt stuff before, but could not remember where, so that was a help.
Again, anybody else have experience with this swap? What about parts availability for the 230? Seems it should be better at least than the 216...
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
10-22-08 07:21 PM - Post#1548003
Hi I put a 292 in my 50, same motor family, I made my mounts as the mounts are stagered on the 292 but I think the 230 or 250 are the same as the V8's I believe some one makes a cross member and motor mount that bolts in or welds in, your choice. I'm not much on pictures but would be glad to help if I can. Mike
EdG'52
EdG'52
Loc: Eastern Pennsylvania
Reg: 01-11-04
10-23-08 02:12 PM - Post#1548435
I rebuilt and dropped in a 1972 250/PG/rear into my 1952. This swap is very easy to do. I bought the mounts and bolt in adaptors from Chassis Engineering and fabbed the trans mount. The rear swap was also easy just by following the tech articles in the forum.
A couple of notes; I left the engine sitting up a bit so that I can get at the bell crank without removing the engine. I set the engine as far back as possible while still allowing clearance for the valve cover to be removed. Using this setting I chose to run an electric fan vs relocating the radiator.
I say go for it and let us know if you have any questions during the project!!
http://s377.photobucket.com/albums/oo217/EdG1952/ C...
Ed
Ed
'52 Coupe Ledsled
in process...
jmschristiansen
Reg: 09-02-08
10-23-08 05:08 PM - Post#1548551
    In response to EdG'52
Thanks Ed, great pictures!
Looks like fun.
Are you using the stock 3 speed shifter? How have you worked out the linkage?
The guy at Stovebolt (bought their motor mounts) said I could use the stock crossmember "with an extension". Any idea what he meant?
Thanks again
10-23-08 05:49 PM - Post#1548586
The rear mount on the PG is farther to the rear than on your stock 3 speed. This means that the PG mount will land behind the stock crossmember. If you want to see how far, you can measure the distance from the mount to the front face of the bellhousing on both transmissions.
EdG'52
EdG'52
Reg: 01-11-04
10-24-08 02:02 AM - Post#1548721
I went for a floor shift and Monte Carlo swivel seats. For the trans mount I cut out the center section of the crossmember and fabbed a mount that can be raised, lowered or unbolted just in case I needed to pull the motor or want to switch to a differant tranny down the road. This also helped set the pinion angle. Ray is correct that the PG mount will sit further back. I believe it was just about two inches. Sorry I do not have any good pic's of the mount that I made up.
Ed
Ed
'52 Coupe Ledsled
in process...
jmschristiansen
Reg: 09-02-08
10-25-08 06:57 AM - Post#1549562
I brought home the drivetrain last night, and looked up the casting #, shows 230 or 250, application in chevy / olds, 67 thru 72. Have not been able to locate info on the serial #.
Any ideas? Here is the info I have:
Casting #3921968
Serial #F0911AN
Heading out to wash it now, will know more later, including info on the powerglide & rear end.
Thanks,
jmschristiansen
Reg: 09-02-08
10-25-08 01:01 PM - Post#1549766
I picked up the entire drivetrain out of a '69 Camaro, washed it, and am now hoping someone can help me identify the components:
Inline 6, casting #3921968, says GM 69 underneath that, then CON 2, and the "clock" is at the 4 position, serial #F0911AN
Can't locate casting or serial numbers on the head
The intake has what looks like a casting #3923418, GM 36
The carburator is a 1 barrel "Monojet", "Factor tested Carburators" 7041021, 134-71 1D
The exhaust has a number, a big "GM", with "932" even bigger next to it, with 3915 underneath the "GM", which makes it look like it could be combined to make a casting #3915932.
Powerglide, can't find any markings other than patent #s and a hand written #82272
Rear axle, has 67890 on the axle tube, and then on the various webs it has: GM 71, 3969340(casting #?), NF, and 6309. The cover is held on with 10 bolts.
Any help I can get, regarding displacement, original application, ratios, etc would be greatly appreciated.
Thanks,
Royer
Needs to Get Out More Member
Loc: Bloomfield Hills, Michiga...
Reg: 09-25-01
10-25-08 01:34 PM - Post#1549785
The 6-cyl. engine originally installed in a '69 Camaro would have been a 250 cubic inch engine. The two-speed Powerglide would have been the familiar aluminum case job that was used in most Chevy's (except the old "235" six) from '62 on.
Royer
jmschristiansen
Reg: 09-02-08
10-25-08 02:02 PM - Post#1549809
    In response to Royer
Thanks Royer,
I am really hoping someone with a book can give me some information, as I don't know that any of these components are original to the car. The PO thinks they are, but he only had the car a couple years, and bought it from another guy who only had it a short time, so it is difficult or impossible to determine any of the history behind this.
10-25-08 02:40 PM - Post#1549829
Casting numbers won't always provide positive identification, because the same casting was often used for several years. What you need are the casting DATES. This is true even when you have the stamped number on the engine.
The rear axle is easy because you can count the ratio directly. Mark the pinion yoke and the housing close to the seal. Lift one wheel (or drum) off the ground. Now turn the wheel exactly TWO revolutions and count how many times the yoke turns, estimating any fractional turn as closely as you can. That number is your axle ratio.
If the wheel is difficult or impossible to turn, you may have posi. In that case, jack both wheels off the ground, turn either of them only ONE revolution, and count the pinion turns as above.
jmschristiansen
Reg: 09-02-08
10-26-08 10:43 AM - Post#1550333
I found a site that decoded my serial #s, turns out I have a 230. Looks like it may actually be the engine original to the car.
So far though, I have not located spec's on the powerglide. Can't even find any identifing #s on it.
The site is a Nova page: http://novaresource.org/codes.htm
Thanks for the help,
bowtie67
Loc: Loudon, NH
Reg: 12-06-03
10-30-08 02:55 AM - Post#1553089
Is there any issues with the stock steering components using the 70's era 250 cylinder? Also I talked to Stovebolt about this swap and said that there was some firewall modification needed, does anyone know what mods he is talking about or has anyone not had to modify it? I have a 76 Nova as a donor vehicle with a 250 & T-350 trans. We will be bringing the car home this weekend, 2 previous owners have not gotten the orginal engine to run, but is supposedly supposed to. I am hoping it does so I can focus on other things and save the swap out till next year being I sm still finishing up my 48 Coupe this winter.
Edited by bowtie67 on 10-30-08 02:56 AM. Reason for edit: No reason given.
10-30-08 10:04 AM - Post#1553291
    In response to bowtie67
No firewall modification is needed for the head that uses a separate intake manifold. Does your engine have the manifold in one piece with the head? If yes, is this why Stovebolt is saying you will need to modify the firewall?
EdG'52
EdG'52
Reg: 01-11-04
10-30-08 02:29 PM - Post#1553485
Having done the 250/glide swap, I can tell you there is no firewall mod needed. You may need to modify the frame bracket just a bit as it will interfere with the steering box arm. This was a very minor thing to do with a grinder.
I chose to modify the firewall braces while I had the body off the car. I did so because I have grand thoughts of putting a big block in somewhere down the road - plus I do not like the looks of the stock braces. There are pic's of the firewall brace mod's in my alblum link. This was also easy to do. Simply drill out the spot welds, remove and trim down the braces and relocate them outward a bit.
Ed
Ed
'52 Coupe Ledsled
in process...
bowtie67
Loc: Loudon, NH
Reg: 12-06-03
10-30-08 03:19 PM - Post#1553517
currently the head has the intgral manifold, he also told me I had to chop some sort of chunk off of either the block or head. The current 216 is supposed to run but the 2 previous owners couldnt get it to run, if it is capable of running I can get it to run, question will be how it runs will determin if the 250 goes in now or later, I am prefering later giving me more time to find the earlier style head.
Execution time: 0.286 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:04 AM
