Username Post: Head weights        (Topic#200861)
Jim.Biron
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
10-13-08 04:44 AM - Post#1540819
Whats the difference in weight between a
1) SBC Aluminum head and an iron head
2) BBC Aluminum head and an iron head
Is there some site that lists these kinds of data?
What about complete SBC vs. BBC weights. (I know there are variables but maybe short block weights would be best).
www.HudsonValleyCruise.com
DragRacer383
DragRacer383
Loc: Arkansas
10-13-08 06:51 AM - Post#1540881
    In response to Jim.Biron
I weighed one of my Dart Iron heads. 48#
I weighed both of my Pro action Aluminum heads
49#, So around 50# difference. IIRC
Later,Glen
artak
artak
Reg: 05-22-05
10-13-08 06:54 AM - Post#1540883
    In response to DragRacer383
  • Some other website Said:
A bare aluminum casting, less valves and springs, weighs 19 pounds, versus 44 pounds for a bare cast iron head
I bet there's a huge difference in weight between iron and aluminum intakes as well. There is a lot of weight to be saved just by using those aluminum parts.
By the way, I read recently that the fear of aluminum heads losing HP from heat loss can be totally canceled just by making the casting a bit thicker around the chambers.
I recently weighed a TH250 and lockup converter, they were 110lb and 48lb respectively.
Casting Numbers
HYPR
HYPR
Loc: Shaking and Burning!
Reg: 07-19-01
10-13-08 07:12 AM - Post#1540891
I remember reading in a thread that the approximate wieght difference between a SBC and a BBC was in the nieghborhood of 175-185 pounds.
For what it's worth the shipping wieght of a LS2/4L60E and all the engine accessories, A/C,PS,Alternator,etc weighs in about 75 pounds less than an iron head SBC motor alone. (found that little tid bit when I sold my LS2/4L60E combo)
Bob
Malibu1974
Malibu1974
Loc: Ottawa Ontario, Canada
Reg: 12-30-03
10-13-08 07:41 AM - Post#1540906
    In response to HYPR
I weight a BBC 781 head vs. an Edlebrock aluminum bare casting
781 = 80 lbs
ebelbrock = 31 lbs
I never had a chance to way the edelbrock fully assembled
1974 Malibu Classic
427 big block
4145 lbs w/ driver
7.45 @ 91.5mph 1/8 mile
11.79 @ 113mph w/ 1.61 60ft
11.05 @ 123mph on a 150shot spinning alot!
http://www.cardomain.com/ride/566156/1
http://www.youtube.com/user/74Malibu
10-13-08 08:44 AM - Post#1540953
    In response to Malibu1974
depends on the iron head. there are lightweight gm heads. there are also heavy aftermarket heads like my sportsmans.
10-13-08 10:54 AM - Post#1541027
    In response to bobb
I have weighed old 50s-70s SBC heads at 42 lb each.
Aluminum is a little over 1/3 the weight of iron or steel, so if an aluminum head had the same thicknesses everywhere, the aluminum head would weigh 14 lb. But they're thicker in most places. The 19 lb estimate is a good one.
And, no doubt, the late model 305 heads will weigh less than 42 lb and the aftermarket iron ones will weigh more.
Just how close do you need to be? Closer than this, you better get some heads and put them on the scale yourself.
Petroholic
Petroholic
Loc: Moses Lake, Wa.
Reg: 08-12-05
10-13-08 11:40 AM - Post#1541056
SBC vortecs I just ordered:
47# complete except rockers.
P.S. cast iron
Edited by Petroholic on 10-13-08 11:41 AM. Reason for edit: No reason given.
Jim.Biron
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
10-13-08 12:00 PM - Post#1541063
    In response to Rick_L
Based on these great posta... and some other info I received how does this sound?
For BBC a pair of ALUMINUM will save about 75 lbs
Foe SBC a pair of ALUMINUM will save about 50 lbs.
Did I get that right?
Execution time: 0.38 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:36 AM
