Username Post: 5.7 Vortec Power Upgrades        (Topic#197808)
trimixx
Loc: Phoenix, Az
Reg: 12-26-04
09-01-08 12:34 PM - Post#1512554
Im looking for some ways to maximize power and mileage in my 1998 CK2500. Its got a factory 5.7L Vortec which I believe is rated at 255hp factory. Right now if I drive it easy, she gets about 15mpg. Im looking to push my numbers closer to 300hp and 18+ MPG... any and all suggestions are welcome. Ive had some people tell me a simple ECU programmer will do the trick, others tell me intake and exhaust...
`72 Elko Custom 350ci/TH350 '69 Vette Intake w/ 4bbl edlebrock Body/Interior under construction
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
09-01-08 12:36 PM - Post#1512556
    In response to trimixx
One Word.
Duramax!
Might search over in the 88-98 forums and see what they are doing for these until someone else chimes in.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
09-01-08 02:38 PM - Post#1512673
    In response to fritz1990
Increase power, decrease mileage. You can't have both!
If you want some real power, throw a supercharger on it. It's too bad Whipple no longer offers Vortec kits; they've updated to pretty much LSx engines only for their GM offerings. There's other brands out there, though.
Senior Chevytalk Moderator
09-01-08 03:16 PM - Post#1512698
    In response to someotherguy
Reprogram the PCM. You'll get better MPG. Power is minimal. I used www.wait4meperformance.com.
Best $86 bucks spent on my Jimmy. The 4.3 can get 20 MPG at 80 MPH!!
09-01-08 03:20 PM - Post#1512699
He asked for more power, along with more MPG. Not just more MPG.
I don't know how you can push a Vortec 5.7 to 300 HP AND take it from 15 mpg to 18+ mpg; it pretty much defies the laws of nature.
Being a K series (4WD) and a 2500 isn't helping, either. Got weight and gear ratios working against you. If it's a real 2500 (8600 gvwr) and is spinning a 4L80E and 14 bolt rear, that's sucking down the MPG's, too.
boogie
boogie
Loc: Louisiana
Reg: 07-11-02
09-01-08 04:34 PM - Post#1512751
I agree!
I can't say for the 350 Vortec but...I just had my 2008 5.3 tuned by Blackbear Performance and I picked up both MPG AND power. My truck is a totaly different driving experience with better MPG to boot!
'85 GMC C1500 SWB 355 sbc
Edited by boogie on 09-01-08 04:35 PM. Reason for edit: No reason given.
09-01-08 04:57 PM - Post#1512771
  • someotherguy Said:
It should be possible. I have a ZZ4 carbed getting 19+ at 70 MPH. 355+ HP makes for a lot of fun.
Read about PCM programming.
Edited by gchemist on 09-01-08 05:00 PM. Reason for edit: No reason given.
09-01-08 05:01 PM - Post#1512774
Okay you guys, please look again at the specifics instead of generalizations and engines/vehicles that have nothing to do with the original poster
1998 K2500, Vortec 5.7, currently getting 15MPG if he drives it "easy." Wants 300 HP and 18+ MPG. I have $10 that says it ain't gonna happen.
josh_cossette
Reg: 08-04-10
08-04-10 07:41 PM - Post#1955932
Well i know that it might not get you the the exact numbers your looking for, but if you invested in a good set of headers and full exhaust,cold air intake and dual electric fans it would help alot. You can get both mileage and power from those three upgrades and there are probably more that i'm unaware of.
1996 k1500 5.7L vortec, 5 speed, stock...for now
Execution time: 0.461 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:26 PM
