Username Post: K1500 pitman arm removal?        (Topic#195970)
chrisk1500
chrisk1500
Loc: Saskatchewan, Canada
Reg: 10-30-04
08-08-08 01:45 PM - Post#1495050
How do you do it?
The front crossmember is right under the nut that holds the pitman onto the steering box.
The problem is that there is a lot of slop on our 97 k1500 and it looks to be where the pitman arm connects to the relay rod. There is a ball joint at this point. As far as I know, you can't take the ball joint out of the pitman arm, you have to replace the pitman arm itself.
How do I get it off the steering box? Remove the steering box and do it on the bench?
Thanks,
Chris
07.5 DMAX 2500 HD ext cab, 4x4, Edge EVO Race, 4" straight pipe, PPE tie rod sleeves, bushwhacker pocket flares, etc...13 second farm truck!
06 Escalade
15 Sierra - Kodiak Edition
CDAUSA
Needs to Get Out More Member
Loc: Texas Panhandle
Reg: 12-31-01
08-08-08 04:00 PM - Post#1495132
    In response to chrisk1500
Chris, I'm a bettin it takes lots of bad words to start. It's hard enough on a 2WD, I changed it on the 99 and it took over 550# of torque to get it broke loose, and used a puller on the tapered shaft (drag link) because I couldn't get it to break.
Pretty sure I've read here where guys unbolted the gearbox and turned it enough to get in there, but I bet it's a &itch.
TMURF
TMURF
Loc: Lindsay, Ontario, Canada
Reg: 10-14-07
08-08-08 04:51 PM - Post#1495158
I've changed lots of them. Just unbolt the steering box and move it into a position that allows you to get a pitman arm puller on it. It's not the easiest job to do by yourself. If you can get someone to hold the box in place it would help. Make sure you put the new arm in the same place on the shaft as the old one.
1924 Chev Superior Touring
1948 Chev Fleetmaster 2 door sedan
1968 Mercury Cougar XR7
1961 Buick Lesabre Convertible
1996 GMC K1500
chrisk1500
chrisk1500
Reg: 10-30-04
08-08-08 07:25 PM - Post#1495254
    In response to TMURF
Ugh...sounds like a nightmare...I'll let you know how it goes...
06 Escalade
chrisk1500
chrisk1500
Reg: 10-30-04
08-13-08 03:47 PM - Post#1498742
That was easy...took it to a garage to have it done..
Took about an hour and a half...the truck needed a front end alignment anyways....
06 Escalade
Phazer
Phazer
Loc: Armpit of the Universe
Reg: 10-10-03
08-13-08 06:14 PM - Post#1498880
What's the matter Colonel Sanders...... CHICKEN??
Just playin. I'm getting ready to do one in a week or two.
My "To Do List" for this weekend:
Nothing but womens names...
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
chrisk1500
chrisk1500
Reg: 10-30-04
08-13-08 07:10 PM - Post#1498931
    In response to Phazer
LOL
You know me Phazer.....I do everything I can by myself but sometimes it is easier to leave it to the pros....
At least I don't expect my father in law to do it for me....
06 Escalade
CDAUSA
Reg: 12-31-01
08-13-08 07:20 PM - Post#1498936
That's FFIL
Phazer
Phazer
Reg: 10-10-03
08-13-08 08:29 PM - Post#1498972
    In response to CDAUSA
OOHHH BURN!!!!
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
CDAUSA
Reg: 12-31-01
08-13-08 08:58 PM - Post#1498985
By the way, I've been wonderin about the torsion bars??
Phazer
Phazer
Reg: 10-10-03
08-14-08 03:37 AM - Post#1499034
It's just hanging there with the a-arm on it irritating me.
I had to stop for a couple of days to do some lawnmower repair.
It's not getting lower bushings. I'm gonna put the lower arms back in and then just replace the lower ball-joints. All the BJ's are original and rivited in. That's gonna be a PITA.
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
CDAUSA
Reg: 12-31-01
08-14-08 04:43 AM - Post#1499062
Uuuuuuuh, yep!
dirk33
Reg: 12-30-02
12-08-08 10:35 AM - Post#1580177
How much did you pay to get the new pitman arm put on?
boogie
boogie
Loc: Louisiana
Reg: 07-11-02
12-08-08 05:54 PM - Post#1580520
I take the complete box out on a 4WD and change it on the shop table.
'85 GMC C1500 SWB 355 sbc
Execution time: 0.205 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:16 AM
