Username Post: push rod length        (Topic#192686)
george88gta
george88gta
Loc: new york
Reg: 04-23-03
06-24-08 11:13 AM - Post#1463062
In the process of installing new aluminum heads on my 350. It originally had a flat tappet cam and the head builder sent me .100" longer push rods to compensate for the larger deck height. I am switching over to a roller cam. The stock roller lifter push rods are 7.122" long. I have only found ( so far) 7.200" and 7.250" push rods. Is it worth getting a solid roller and an adjustable push rod to verify correct length or just use one of the two available? Cam kit came with matching rocker arms and valve springs.
55chevy383
55chevy383
Loc: Noble, Ok.
Reg: 12-08-05
06-24-08 12:37 PM - Post#1463124
    In response to george88gta
Absolutely 100% check for correct length! Any good cam company cam make you a set of pushrods to the length you supply them. I wouldn't guess at the correct length or settle for what's available. Just my .02 worth.
Phil
11.22 @ 117 N/A.
Phil's '55
Tommy518
Tommy518
Reg: 01-20-03
06-24-08 01:52 PM - Post#1463198
Would these be ProComp heads by chance? I just installed a set of ProComps and they suggested the same change in length of pushrod. I'm also running a roller cam with retro roller lifters and need to lengthen my pushrods. I'll be interested to know what size you settle on.
Good luck.
'69 Camaro 396 SS-RS, TCI 4-link, Tremec 5-sp, Ford 9", 10pt-cage, etc...
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
06-24-08 01:58 PM - Post#1463208
Have you thought about using one of your hydraulic lifters and a checking spring? There's not enough force to make a witness mark on the valve stem tip, but you can eyeball the roller tip-to-stem contact (or use a magnifying glass) to adjust the pushrod to the correct length. The goods news is there also isn't enough pressure to compress the lifter plunger.
CompCams P/N 4758-2
george88gta
george88gta
Loc: new york
Reg: 04-23-03
06-24-08 03:37 PM - Post#1463297
    In response to Tommy518
Yes, same heads. I have found several tools for checking the pushrod length. I plan to stop by my friends machine shop next week and see what method/tools he has and if he will let me borrow them. Looks like I will need an adjustable pushrod as a minimum. Dont have the cam installed yet and havent ordered the lifters, so I have time for research. I like that CompCam spring idea, no stress on the valve train.
mnblaster
Reg: 04-26-04
06-24-08 03:55 PM - Post#1463315
I used this method with a Comp Cams adjustable mic-style pushrod, no need to buy springs and take lifters apart.
http://www.carcraft.com/techarticles/116_0401 _sett...
george88gta
george88gta
Loc: new york
Reg: 04-23-03
06-25-08 04:22 AM - Post#1463625
    In response to mnblaster
I bookmarked this article, very helpful. Thanks. Looks like I will have to see what my buddy has and if he cant help then I will start with an adjustable pushrod. Thanks for the help guys.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
06-25-08 02:02 PM - Post#1463979
George, how does that method keep a hydraulic lifter from compressing? Am I missing something?
george88gta
george88gta
Loc: new york
Reg: 04-23-03
06-25-08 02:23 PM - Post#1463992
    In response to MikeB
Mike, I reread the article. As I read the process, you "place" the rocker arm back in to position and do not perform the adjustment ( tighten adjusting nut until drag on the pushrod) this process seems to not compress the roller piston to its mid-point. This begs the question, "does compressing the piston to its midpoint have no effect on valve train geometry?". I checked with Edelbrock today, their heads also have the +.100 pushrod requirement. They state that if you are using a "full roller rocker arm" just use the 7.200" pushrod. That confuses me, what difference does the type of rocker make? I plan to get an adjustable pushrod and do it the right way.
greg_moreira
Reg: 10-06-03
06-25-08 03:09 PM - Post#1464017
you are correct that there is possibility of compressing the lifter with this method giving a false reading. The method itself is sound...but I dont like the possibility of compressing a lifter. So......
A few ways to combat this. One, use a solid lifter cause its definitley not going to compress. However....youve got to be sure to measure and make SURE there is no difference in lifter height as well as the depth of the pushrod cup/holder compared to the hydralic lifter you are going to use.
If there is a difference...you need to factor that difference in when doing your final calculation.
Another way....use an old hydraulic lifter, but take it apart and modify it so that it wont compress. Effectively, you are using the solid lifter method now...but it might be more convenient just in case you dont have a true solid lifter anywhere to try it out with.
Lastly.....using a very light checking valve spring. This will help keep from compressing the lifter any, giving an accurate reading. But, its also my least favorite method.
Id just prefer one of the previously mentioned methods with a solid type lifter of the same measurements using ALL of the exact same components that will be used when the motor is truly run to guarantee nothing happens with the lifter.
Edited by greg_moreira on 06-25-08 03:12 PM. Reason for edit: No reason given.
motorman
Loc: south western pa.
Reg: 01-25-00
06-25-08 08:11 PM - Post#1464260
the best push rod length checking tool ever made for use with roller tipped rocker was made by "ferry's aluminum cylinder head & block repair" dallas texas. if anyone has a march 1995 hot rod magazine go to page 158 to see this tool.
retired race engine builder,former NASCAR tech inspector. new corvettes owned 1959,1962,1963,1964,1965, 1966,1997,1999,2002,2005, 2008 plus 30+ other chevy cars and trucks along the way. 2008 corvette sold and waiting on a C-7.
motorman
Reg: 01-25-00
06-26-08 09:27 AM - Post#1464612
    In response to motorman
i have my instruction sheet for this tool and if someone wants to post it here i can e mail it to them.
fcsallan
Loc: Port Saint Lucie FL
Reg: 10-13-07
06-26-08 12:05 PM - Post#1464748
I can post it for you if you wish.
fcsallan@comcast.net
motorman
Reg: 01-25-00
06-26-08 12:26 PM - Post#1464762
    In response to fcsallan
i will send it off,thanks
fcsallan
Reg: 10-13-07
06-26-08 12:52 PM - Post#1464778
Lets see if this works
Direct link to image
motorman
Reg: 01-25-00
06-27-08 05:01 AM - Post#1465239
thanks for posting and ZOOM to +200 to be able to read.
Execution time: 0.429 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:53 AM
