Username Post: Rear Main Seal Replacement on an assembled engine        (Topic#192063)
clemsparks
Loc: Columbia, MO
Reg: 05-21-03
06-16-08 09:37 AM - Post#1456835
Hey all,
I've got a used 350 (Two piece RMS) that I plan on putting into a car. I was wondering how easy or hard it is to snake in a rear main seal with the bottom end assembled. Do you just remove the rear cap and simply feed the seal in? Does this work ok? Or should I leave "well enough" alone?
I'm weighing the options of take the chance on an unknown seal that may weep a bit...or should I just go ahead and replace the RMS?
Thanks,
Clem
If the inventor of the hammer were still alive today, he'd be penniless as a result of liability claims.
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
06-16-08 10:37 AM - Post#1456887
    In response to clemsparks
If it is out, replace it.
The easiest way to do it is to remove the oil pan and loosen all the main caps. This will allow you to lift the crank slightly out of the saddles, so you can slide the new upper seal in place. You don't have to remove or loosen the rod caps to do this.
You can sometimes use a tool called a "sneaky pete" to slide in a new seal on the upper side, but it only usually works well with rope seals. I've tried it on neoprene, it wasn't pretty.
billydonn
Junior Contributor
billydonn
Loc: Omaha, NE
Reg: 10-02-07
06-16-08 05:27 PM - Post#1457249
Change it with engine on stand if you can. But it's not too big a deal to change it in the car if you can get the oil pan off okay without issues. A set of sharp dental-type instruments with hooked or bent ends can come in handy.
66 C-10 Stepside
350TPI Engine
Tremec TKO 600
Click for Pitures: http://community.webshots.com/user/billydonn
Click for Truck Video: http://good-times.webshots.com/video/3084715920102...
Edited by billydonn on 06-16-08 05:28 PM. Reason for edit: No reason given.
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
06-16-08 06:57 PM - Post#1457345
    In response to billydonn
When you start putting in the upper half of the seal, rotate the crank slowly in the direction the seal is going. This usually helps push the seal around the crank, but go slow. Don't forget a small dab of silicone on the ends.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
ranman
ranman
Loc: The cold wet and windy O...
Reg: 03-10-01
06-16-08 11:31 PM - Post#1457524
    In response to fritz1990
Regards, Jeff
Isn't there a speacial sealer made for this?
If plants ruled the world, would they regulate oxygen?
BrianEsser
BANNED
Loc: North Star, Ohio
Reg: 06-30-01
06-17-08 07:08 AM - Post#1457708
    In response to ranman
I use anerobic(sp?) sealer myself and never had an issue. I believe thats what you're refering to.
ranman
ranman
Reg: 03-10-01
06-17-08 07:17 AM - Post#1457717
    In response to BrianEsser
That's the one.
billydonn
Junior Contributor
billydonn
Loc: Omaha, NE
Reg: 10-02-07
06-19-08 07:13 AM - Post#1459530
When I did mine I staggered the upper/lower joint a little by rotating so that it didn't line up with the bearing cap joints....just a few degrees.
66 C-10 Stepside
350TPI Engine
Tremec TKO 600
artak
artak
Reg: 05-22-05
06-19-08 11:26 AM - Post#1459732
Same here. It's a good idea and it's fairly easy to do.
Casting Numbers
Execution time: 0.965 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:10 PM
