Username Post: stock head gaskets thickness        (Topic#18667)
loudpedal
Loc: corner of Walk & Dontwalk...
Reg: 07-28-00
Re: stock head gaskets thickness
09-05-02 10:15 AM - Post#123387
    In response to mr wabbit
There were no steel shim head gaskets used on factory assembled SBC motors from the 80's, as the heads were all of lightweight casting design and there was insufficient support for the shim head gaskets.
The typical FP replacements are .039" compressed.
Detroit Gasket (now Corteco) has (used to have a composition head gasket of about .025" compressed that will work on the later lightweight heads. The .021" compressed shim head gaskes aree still availiable from many suppliers but are a problem when used with lightweight heads unless the motor is done right.
Anonymous
09-05-02 01:07 PM - Post#123388
    In response to loudpedal
The Impala version of the LT1 used a thin head gasket I believe, but the cooling passages were different. I think you want the FelPro 1094 gasket that compresses to about .020. The old factory steel gaskets compressed to about .022 I think.
DragRacer383
DragRacer383
Loc: Arkansas
09-05-02 03:15 PM - Post#123389
    In response to
[QUOTE]Originally posted by loudpedal:
[B]There were no steel shim head gaskets used on factory assembled SBC motors from the 80's, as the heads were all of lightweight casting design and there was insufficient support for the shim head gaskets.
With all you read about using them with the light weight heads you wouldn't think they did. I know for a fact that they used them up to 84. This past week i tore down a 82 and 84 305 both had factory steel shim gaskets. every main was spun in the 82 so the need for the 84.
84 Silverado
84 Z-28
86 Mustang SS , 383 100 shot of N20 6.9 in the 1/8www.geocities.com/poorboysspeedshop
Later,Glen
mr wabbit
mr wabbit
Loc: IL
Reg: 02-26-02
09-05-02 03:55 PM - Post#123390
    In response to DragRacer383
well when i removed the 624 heads of this engine it had the steel shim gaskets on it, so,,,,, its an 85 burb, so,,,
thanks though.
why would thinner casting head mean that thinner gasket couldnt be used ? that doesnt even make any sense.
what does thinner gasket or not have anything to do with casting of a head? ?
just trying to learn all i can...
thanks
Randy
Lincoln Il
1982 Trans Am WS7
305 TH350 7.5" for now
http://smg.photobucket.com/albums/v298/fast68/ra nd...
mr wabbit
mr wabbit
Loc: IL
Reg: 02-26-02
09-05-02 09:10 PM - Post#123386
what thickness are the factory installed mid '80's steel shim head gaskets and wjat thickness are the blue fel pro repacement composite gaskets and can napa or autozone get anything thinner ? were there any SBC engine applications ever that used any thinner gaskets from factory ?
im sure others would like to find out some info on this, please direct me to any threads
you may know of that already discuss some of this maybe
thanks
Randy, Lincoln IL
fastr68@yahoo.com
Randy
Lincoln Il
1982 Trans Am WS7
ZZiggy
ZZiggy
Loc: Joplin,MO
Reg: 04-18-02
09-06-02 03:14 AM - Post#123391
stock chevy gaskets are 0.018" fel-pro blues are 0.039"
71 Camaro 355 NA
11.1650 @ 119.30
1.5028
mr wabbit
mr wabbit
Loc: IL
Reg: 02-26-02
09-07-02 09:32 PM - Post#123392
    In response to ZZiggy
over twice as thick ??? why they do that for ???
they cant make composite ones that thin, or ??
so how can anyone get any thinner ones without having to order any ?
damn...
thanks
Randy, Lincoln IL
fastr68@yahoo.com
Randy
Lincoln Il
1982 Trans Am WS7
Anonymous
09-08-02 02:36 AM - Post#123393
The Mr.Gasket standard rebuild gasket set contains the steel head gaskets, whole set for under 30 bucks. (This was correct last year anyway.)
Desertvette
Loc: Las Vegas, NV,USA
Reg: 08-15-01
09-08-02 05:33 AM - Post#123394
    In response to
GM has a .026 composite gasket p/n 3830711. ROL HG31600 .025 steel shim from performance gasket.com less than $20. Victor 1178ssb .020 stainless steel available Napa special order about $40. and Mr Gasket 1130 .018-.020 available from Summit about $20.00. Have heard as stated not to be used with lightweight castings as far as the steel shim goes. That's why I listed the GM composite. Might just be what you need and fairly thin
Bob
mr wabbit
mr wabbit
Loc: IL
Reg: 02-26-02
09-08-02 09:30 PM - Post#123395
    In response to Desertvette
i need to go for a thinner composite one, i need to get hold of local dealer and see about that GM comp one,. hmmm...
thanks
Randy
Lincoln Il
1982 Trans Am WS7
SteveStreeter
Needs to Get Out More Member
SteveStreeter
Loc: Kettle Falls, WA. USA
Reg: 01-19-01
09-09-02 03:33 AM - Post#123396
The Felpro #1094 is a .015" compressed thickness and has no stipulation as to which heads it works on. This is a rubber like coated steel shim gasket. The only stipulation is for surface irregularities. The surface must be free of defects.
Steve
mr wabbit
mr wabbit
Loc: IL
Reg: 02-26-02
09-30-02 12:05 AM - Post#123397
    In response to SteveStreeter
thanks
Randy
Lincoln Il
1982 Trans Am WS7
Execution time: 0.369 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:20 PM
