Username Post: lifter noise        (Topic#185060)
Finajoe
Loc: Florida
Reg: 07-01-04
03-19-08 01:45 PM - Post#1392002
OK guys this is a bit long but I need some help.
I have a BB 73 chevelle with the original engine and everytime I start it up again after it's hot I have a loud lifter noise. Embarassing leaving a car show after a few hours with a lifter taping away.
Decided that I'd get new chevy lifters and change the old ones. When I got the intake off and pulled the lifters I could see that 2 lobes of the cam didn't look right so I pulled the cam and replaced it with a crane cam with the same specs as my LS4. Since the car is all original I wanted to keep it that way.
So I changed the cam and lifters and everything went smooth and it started right up and ran fine. The next day I changed the oil and ran it again and shut it down and waited for an hour or so and the lifter is banging away again. Not happy!
Seems everytime I bet the car hot and the restart it in an hour or 2 the lifter starts banging. I brought the car down to a local mechanic who knows the car and works and races big block and he can't believe I have the same problem. He seems to think maybe it's a valve guide or a rocker are.
Any thoughts???
strokersix
Reg: 04-05-03
03-19-08 02:01 PM - Post#1392020
    In response to Finajoe
Try to determine which side of the engine it's coming from and remove that valve cover. Lay your finger on each rocker while the engine is idling. You will probably be able to feel which one is tapping. I'll bet it's a rocker arm, pushrod, or guideplate issue. While you are at it, clean off the upper area of the pushrods and put a paint pen mark on each pushrod. That will give you a quick visual whether they are spinning like they should. They may not all spin at idle but as long as they spin when you rev it up that's a good indication that the lifters are spinning properly.
69 Caprice 454 TH400 (original 427 in storage) 72 Nova 410 big block 3 speed Saginaw (was 306" inline six)
55chevy383
55chevy383
Loc: Noble, Ok.
Reg: 12-08-05
03-19-08 03:06 PM - Post#1392051
    In response to strokersix
Are you using stock lifters? If so did you change the retaining nut for the lifters, or re-use the old ones? If you reused the old ones, you may have one that's not staying tight and it's backing off and letting the lifter tap.
Phil
11.22 @ 117 N/A.
Phil's '55
Finajoe
Loc: Florida
Reg: 07-01-04
03-19-08 03:17 PM - Post#1392058
    In response to 55chevy383
Phil
Phil, I reused all the old stuff but the lifter makes noise only at certain times. I can understand it backing off but it would make noise all the time if that were the case.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
03-19-08 04:47 PM - Post#1392118
Does it make noise for only a few seconds after start-up? How much preload do you have on the lifters (turns past zero lash)?
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
03-19-08 05:13 PM - Post#1392135
    In response to MikeB
There is a hole drilled into the lifter valley cap on the front of the block, behind the timing chain. This hole lube the timing chain and sprockets. It also bleeds air out of the end of the lifter galley. If this hole was/is plugged, it can cause lifter noise during startup.
There are also BBC blocks that have a tendency to bleed down oil pressure when sitting. There are oil filters out there that have a one way valve in them to prevent this oil system bleed down. If I were you, I would try this style of filter first to see if it fixed your problem.
Someone here probably has the Fram number for the filter.
Finajoe
Loc: Florida
Reg: 07-01-04
03-19-08 06:36 PM - Post#1392202
    In response to Vaughn
MikeB, I have 1/2 turn lash on the lifters.
Which is what Crane says is correct.
Vaughn, I used a wix racing filter with this feature and VR1 oil and EOS.
The lifter that makes the noise only does it after the car is run to full temperture and then sits for a while. When I start it up then the lifter clacks as the one I took out did. This goes on for about 5 to 8 minutes and then goes away. The reason I did the job is to get rid of this problem. Seems like I did this whole job for nothing.
Strokersix, I hope that your right that it's a rocker arm, guide plate or push rod. I rule out the push rod because I checked them all out when I did the job. Now I have to find out which lifter is doing it and change the guide plate and the rocker. Do you think it could be a valve guide, I sure hope not, don't want to take the whole thing apart again.
74elco for73SS
74elco for73SS
Loc: so cal
Reg: 04-30-04
03-19-08 09:43 PM - Post#1392319
also you could try moving switching the rocker arm assembly from one valve to another valve and see if the noise goes with it.
55chevy383
55chevy383
Loc: Noble, Ok.
Reg: 12-08-05
03-20-08 05:09 AM - Post#1392409
    In response to 74elco for73SS
I can't see a rocker arm being the sole cause of the noise, unless it's always loose, which would bring me back the retaining nut. Maybe a bad lifter bore and a lifter is hangin' up?
Phil
11.22 @ 117 N/A.
Phil's '55
Finajoe
Loc: Florida
Reg: 07-01-04
03-20-08 07:18 AM - Post#1392480
Phil
I agree that this was one of the things I was thinking about. But when I put the cam in the old lifters cam out very easy and none of them were hung up. Also the new ones just slid right in with no problems. This is making me nuts because I don't see anything wrong. I checked the push rods and the rockers and didn't see anything. I think I have to pull of the valve cover and check the spinning of the push rods.
Finajoe
Loc: Florida
Reg: 07-01-04
03-26-08 04:29 PM - Post#1397273
OK, so far not much luck but here's where I stand.
I brought the car down to a guy who know's big blocks and he's had it for a few days now. He can't seem to find much but the noise continues. It seems that theres not much oil coming up to the rocker arms. Has anyone drilled bigger holes in the stock rocker arms to let more oil up?
Seems the hole in the rocker is off to the side and the puchrods don't line up with this hole. A few of the rockers are getting oil but most are not. We checked the ball in the rockers and one of them is worn and the rocker is a darker color than the others.
We checked the oil pressure and it was at 50 lbs. Any reason why oil would not get up to the rockers?
Since the new lifters have a groove toward the bottom is it possible that the lifter on the low part of the cam is loosing oil as the lifter groove is going lower than the bore.
Vaughn
Vaughn
Reg: 08-08-04
03-26-08 05:52 PM - Post#1397333
Try installing different distributor bases.
The distributor base fits into the right hand oil galley, if it isn't a tight fit you may have oiling issues on the top end (although usually the indicated oil pressure is lower). I have seen this happen a couple of times on SBCs, so I assume that it could also be the case with the BBC.
Some newer aftermarket distributors go so far as to O-ring the distributor base to eliminate leakage from this point.
Finajoe
Loc: Florida
Reg: 07-01-04
03-26-08 06:15 PM - Post#1397349
Vaughn, thanks for the reply.
We did use another dist which was designed for a drill to run oil pressure. The oil pressure was about the same with the drill.
Seems we have oil at the lifters but it's not coming up to the rockers.
What about drilling larger holes in the rockers? Or maybe using new ones to see what happens.
motorman
Loc: south western pa.
Reg: 01-25-00
03-26-08 08:22 PM - Post#1397450
i have heard other people with the same problem with crane hyd lifters some bleed down after setting. there is a fellow over on the NCRS board with the same problem. my advice try another brand of lifter.
retired race engine builder,former NASCAR tech inspector. new corvettes owned 1959,1962,1963,1964,1965, 1966,1997,1999,2002,2005, 2008 plus 30+ other chevy cars and trucks along the way. 2008 corvette sold and waiting on a C-7.
Edited by motorman on 03-26-08 08:22 PM. Reason for edit: No reason given.
Finajoe
Loc: Florida
Reg: 07-01-04
03-26-08 08:51 PM - Post#1397470
    In response to motorman
motorman, I didn't use Crane lifters. I purchased GM original lifters and used a Crane cam.
55chevy383
55chevy383
Loc: Noble, Ok.
Reg: 12-08-05
03-27-08 05:11 AM - Post#1397591
Is it just one or both sides not getting oil to the rockers?
11.22 @ 117 N/A.
Phil's '55
Finajoe
Loc: Florida
Reg: 07-01-04
03-27-08 06:36 AM - Post#1397641
Both sides, yet some oil is coming up to a few of the rockers on both sides. It's very light and not squirting on any of them.
55chevy383
55chevy383
Loc: Noble, Ok.
Reg: 12-08-05
03-27-08 02:13 PM - Post#1397993
Possible bad oil pump, or clogged oil passage?
Phil
11.22 @ 117 N/A.
Phil's '55
strokersix
Reg: 04-05-03
03-27-08 05:10 PM - Post#1398107
I think you've found your problem:
"We checked the ball in the rockers and one of them is worn and the rocker is a darker color than the others."
Finajoe
Loc: Florida
Reg: 07-01-04
03-27-08 05:25 PM - Post#1398115
This motor is original and has never been apart. When I spoke with the original owner about 8 years ago I asked him about the lifter problem and he said it has done it since new. I figured once I changed the cam and lifters that would do it but the problem continued.
Today we replaced one of the rockers with a used rocker the mechanic had at the shop. Within a minute or so oil came up and was running like a river yet the other rockers were dry. We replaced the rockers on one side of the motor and the oil was running all over the place. Tomorrow he's going to replace the other side rockers and put the covers on and let it heat up. Then wait an hour and see if the lifter clacks. I feel pretty good that the problem is solved but I'll know more tomorrow.
The most amazing thing is the rockers don't look any different than the ones we put on. Must be some type of problem with the BB 73 motors because all the rockers are the original ones.
I'm keeping my fingers crossed that this is it.
whitedj
whitedj
Loc: Jacksonville, NC
Reg: 11-16-03
03-31-08 03:44 PM - Post#1400788
Did the new rocker arms stop the clattering on both sides? I am interested, as I have a 454 with the same exact problem.
David
Some people live an entire lifetime and wonder if they have made a difference to the world, but the Marines don't have that problem. Ronald Reagan
hot rod resto
Reg: 07-11-11
07-11-11 03:43 AM - Post#2112862
did you ever figure out that lifter problem it seems im having the same problem and cant figure it out
al72
Loc: Michigan
Reg: 11-05-08
07-11-11 05:23 AM - Post#2112875
    In response to hot rod resto
I also have a stock 454 from a 1974 GMC 3/4 ton with the identical rocker arm oiling problem.
Jims56chevy
Jims56chevy
Loc: chino valley az
Reg: 11-23-04
07-29-11 10:46 AM - Post#2119354
How can a rocker arm increase oil pressure???
56 210 2dr
Execution time: 0.382 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:21 PM
