Username Post: Adjusting Vaccume Modulator?? TH350        (Topic#183310)
Raceman
Raceman
Reg: 05-07-06
02-27-08 04:42 PM - Post#1376179
I have a TH350 in my 75 shortbed. I want to adjust my modulator to get the shifts to come a little later. How do i go about doing that??
75 ShortBed 4x4
BrianEsser
BANNED
Loc: North Star, Ohio
Reg: 06-30-01
02-27-08 05:24 PM - Post#1376212
    In response to Raceman
Do you already have an adjustable modulator in the trans? If you do, simply unplug the vacuum line at the valve and insert a small flathead screwdriver into the nipple and adjust it to how it feels best for you. It will take several times to get it right where you want it.
Raceman
Raceman
Reg: 05-07-06
02-27-08 05:30 PM - Post#1376218
    In response to BrianEsser
THanks... does turning it clockwise make it shift later or does going counter clockwise make it shift later?? Thanks..
75 ShortBed 4x4
BrianEsser
BANNED
Reg: 06-30-01
02-27-08 05:36 PM - Post#1376225
You know. I honestly can't remember at this moment.
Raceman
Raceman
Reg: 05-07-06
02-27-08 05:36 PM - Post#1376228
alrighty... i guess ill try and see what happens!
75 ShortBed 4x4
SLOPENOSE
SLOPENOSE
Loc: west milton ohio
Reg: 05-28-05
02-28-08 05:31 AM - Post#1376495
Raceman I had the same question a while back , here's the link- http://www.chevytalk.org/fusionbb/showtopic.php?ti...
hope this helps
SLOPENOSE
I tried to beat the odds
but the odds retaliated and kicked my butt
70 Chevelle Ragtop 468m/400t
76 Laguna S3 350m/350t
Raceman
Raceman
Reg: 05-07-06
02-28-08 07:01 AM - Post#1376546
    In response to SLOPENOSE
thanks a bunch thats all i needed to know. I couldnt find that
75 ShortBed 4x4
Raceman
Raceman
Reg: 05-07-06
02-28-08 06:15 PM - Post#1376940
After reading what was above i have been messing with it and all it seems to do as i turn it in is make it shift harder not later. I am trying to make this thing shift about 1500 rpm later. I have a 2400 stall converter in it and when i am about 1/2 to 2/3 throttle it is shifting before the torque converter has locked up all the way causing it to jerk. Some help please!!
75 ShortBed 4x4
BrianEsser
BANNED
Reg: 06-30-01
02-29-08 06:45 AM - Post#1377240
Have you checked out governor recalibration kits?
Raceman
Raceman
Reg: 05-07-06
02-29-08 04:17 PM - Post#1377654
I have now gotten a govenor re-calibration kit and am going to install i just dont know where its at!! Under the drain pan or is it under that cover in the rear up on the drivers side of the tranny
75 ShortBed 4x4
Raceman
Raceman
Reg: 05-07-06
02-29-08 05:53 PM - Post#1377728
never mine.... i got it all done!!
75 ShortBed 4x4
rcr3
rcr3
Loc: Manheim Pa. U.S.A.
Reg: 11-24-02
02-29-08 08:14 PM - Post#1377854
Did it help and how hard was it to perform? Ever since i put the 4:10 gears in my '37 it shifts too soon.I read about governor mods,but would like to hear from someone who's done one.Leon
'12 Cruze RS LTZ
'73 Nova hatchback Sold 12/23/12
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
'06 Z71 Sierra Ex Cab
'67 Camaro survivor
Raceman
Raceman
Reg: 05-07-06
03-01-08 05:20 AM - Post#1378014
    In response to rcr3
it was actually VERY easy... You need some good dikes to cut the original nail so you can change the weights. It made it shift just liked i wanted it to. It took me about 45 min total to get it out, change weights and be back out trying it again!
75 ShortBed 4x4
DragRacer383
DragRacer383
Loc: Arkansas
03-01-08 05:36 AM - Post#1378021
    In response to rcr3
www.geocities.com/dragracer383/page2.html
Later,Glen
Raceman
Raceman
Reg: 05-07-06
03-02-08 07:57 AM - Post#1378593
    In response to DragRacer383
okay. I have adjusted this govenor a few times. I can actually do it in about 20 min from start to driving away! Anyway, what keeps happening to me is the 1-2 shift comes early and the 2-3 shift is right on. Is there something i am missing here or what? i am running D and F for the weights and Red and Purple for the springs. Any help?
75 ShortBed 4x4
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
03-02-08 07:57 AM - Post#1378594
I am going through the same thing here allso I am gonna replace my modulator on mon.Where did u get the kit from(weights) ,I may try and cut mine down first and see.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Raceman
Raceman
Reg: 05-07-06
03-02-08 08:06 AM - Post#1378599
    In response to 69_BOWTIE
i got the kit from a local tranny shop. Heres a link to them on summit.
http://store.summitracing.com/partdetail.asp?autof...
i have been playing with the kit and it makes a big difference , i just cant get it perfect yet! i have made 3 adjustments so far and its still not right!
75 ShortBed 4x4
ChevroletR
ChevroletR
Loc: Mt. Airy, Maryland
Reg: 01-24-03
03-18-08 09:25 PM - Post#1391570
I believe turning my vacuum modulator screw clockwise (looking at the vacuum fitting) dragged my shifts out later and firmed them up a little.
1970 Monte Carlo
1988 Buick Reatta
1994 S-10
1984 Buick Regal
1995 S-10
1995 Caprice
2002 Avalanche
2008 Yamaha Raider
Execution time: 8.186 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:08 AM
