 Page 1 of 2 ALL12
Username Post: Pertronix Ignitor        (Topic#179588)
ToddVanSlyke
Loc: Chicago Area
Reg: 09-26-07
01-14-08 10:13 AM - Post#1342487
I'm (relatively) new here and I'm sure this has been addressed but, what the hey, right? What's the opinion of the Pertronix Ignitor electronic ignition thingamabob for a '57 small block? Does it work as advertised? Is it easy to install? Lots of fiddling or does it just do its job efficiently?
Sure would like to install one in my car but I want to know if it's worth it.
Thanks for your help!
Todd
All things considered, a day in the garage is much better than a day in the office.
Ronnie44
Ronnie44
Loc: Tampa Bay, Florida
Reg: 12-23-03
01-14-08 10:31 AM - Post#1342500
    In response to ToddVanSlyke
Easy installation and works as advertised. The instructions were easy to follow and installation was pretty straight forward. I never had problems with mine but others have had them crap out. Always a good idea to keep the points, just in case. If you use the Pertronix coil that is supposed to increase the voltage, make sure that your ignition wires are up to the task and don't forget to increase your plug gap per the instructions.
In memory of George K Fullam(Goodwrench) Died 31 Mar 2005
To view my '57 Bel Air, and my previous '55 & '56 hardtops and '56 Corvette: Click Here
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
01-14-08 11:21 AM - Post#1342528
I have a Crane points eliminator and have heard zero problems with them. Cost about $85.
57 Bel Air 2dr Ht
327 700r4
502-fivespeed-57hardtop
Loc: CT.
Reg: 09-15-07
01-14-08 08:29 PM - Post#1342910
I had a spare Pertronix set for one of my cars but then I rebuilt and used the HEI that came on the motor originally . I have a good friend that bought my late Brothers 57 Bel Air 4 door sedan with the original tired 283 2 brl. automatic. One day as he was visiting he told me how poorly the car was running, I remembered the Pertronix set and I gave it to him along with a spare distributor and told him to try it out. 2 days later he called me in excitement telling me how well the 57 ran now and that he actually got it to go up to 80 miles an hour on the highway, remember this was the original, never been out of the car, well over 100,000 mile motor, with constant blow-by, and was nursed along for many years by my late Brother. Well he has since rebuilt the bottom end, added an original power pack set up, and still has the Pertronix on the motor and its still working great so go ahead and give it a try, got to be better than changing points every 5000 miles, Bruce
Theres no replacement for displacement - 57 Bel Air 2 door hardtop, 502 crate motor, Richmond 5 speed, Currie 9 inch rear. 57 Bel Air 4 door wagon, 327, auto., just a fun driver car.
01-15-08 09:20 AM - Post#1343152
ALL of my engines with a point type distributor have the PerTronix conversion.
Before continuing, let me just say this. The PerTronix, Crane, etc. electronic conversions are just that. They are CONVERSIONS for points. They are not a super duper killer high voltage ignition system. BUT, by their nature, they do provide a better, more dependable ignition source for the engine. Things such as point bounce and the rubbing block and points wearing down are eliminated. Thus, the dwell will remain the same all the time.
For the PerTronix, when used in conjunction with a HD oil filled coil (per PerTronix recommendation), there is a definite improvement in the ignition system.
I'm not advertising for them, but I do have personal experience with PerTronix conversion units and have been quite happy with them. The oldest one that I have in use is 16yrs------------still firing great! I started out with the MSD Blaster II coil (HD oil filled) which is red and painted it black to simulate the appearance of a Delco coil. But when PerTronix introduced their Flamethrower coil, I started buying it. ZERO problems.
PerTronix makes 2 basic versions of their electronic conversion.
One uses a magnetic ring which attaches below the rotor (2 studs go where the 2 screws are for the rotor) and then the module attaches with the same 2 screws that attached the points. This unit DOES REQUIRE removal of the distributor because it is important to install shims between the bottom of the dist housing and the dist gear to remove MOST end play. Also, the magnet ring needs to be shimmed to achieve about .010-.020 gap between the magnet ring and the module. If you are comfortable removing the dist and working on it, this unit is my preferred choice.
The second version is installed with the same 2 screws that attached the points, and it senses off of the cam lobes for the point rubbing block. When installed, this version requires (or did require) that the ignition be turned on and then wait about 3-5 seconds for the module to charge up. The dist does not have to be removed for installation of this version.
Both versions have only 2 wires for connection. One wire is black and goes to the same terminal on the coil where the original balck wire connedted between the dist and coil. The second wire is red and connects to a 12v ignition source. Toooooooooooooooooooooo easy!!!!!
01-15-08 10:27 AM - Post#1343184
Ditto what Tom says. I ran a Petronix on my '54 Chevy 3/4 ton truck for 60,000 miles or so until I sold it. It had a stock 235 with 4-speed granny gear trans. When I installed the Petronix, I figured I better keep the points and cond. in the glove compartment just in case... turned out I never needed them. I sold the truck 4 years ago to a neighbor, and he is still running in.
OldDad
OldDad
Loc: The Great NorthWest
Reg: 06-06-04
01-15-08 11:05 AM - Post#1343211
Just like everyone else I'm happy with my Pertronics in my 57. I have a 891 Dual point distributor, and the only problem was the instruction sheet is wrong for installation unless they have corrected it by now. The system does work great and I'm going to run one in my 52 hardtop with a 6 banger.
The S.O.B. from the factory...
71 1/2 ton, 64 Chevelle SS, 57 2dr Hardtop, 57 2dr Sedan, 57 Corvette, 52 2dr Hardtop, 52 2dr Sedan, and now a 49 Plymouth Coupe, 1930 Model "A", 1934 Ford Truck, all Chevy powered of course.
Farm boy
Farm boy
Loc: Central California
Reg: 11-03-07
01-15-08 11:28 AM - Post#1343228
I am very happy with the Pertronix Ignitor (#1181) I installed in my Camaro two years ago. I pulled the distributor to do the job. I had to shim the distributor gear to get the clearances in spec. The shims were included with the unit. The job took les than an hour with basic hand tools.
I am planning on getting a Pertronix unit (#1183) for my ’56. Has anyone here installed a Pertronix module in a 55-56 distributor? Does the 1183 use magnets or lobe sensing to trigger the unit?
Steve
1967 Camaro
1956 Bel Air
tmsnyder
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
01-15-08 12:09 PM - Post#1343258
Here's a related question I've been pondering. If using one of these Petronix conversions, will it work with a stock overdrive system? To get the OD to kickdown into direct drive there is a circuit which grounds the points to kill the ignition. How does that work with the points-eliminating system?
'56 Chevy 4dr 210 327ci
'97 GMC K1500 Suburban 6.5TD
Topless57
Topless57
Loc: Frankfort, Il.
Reg: 12-26-02
01-15-08 12:24 PM - Post#1343261
Todd, I put one in mine last summer and it works great. The most difficult part of the job was getting the rock hard, dried out rubber grommet out of the bottom of the distributer, to run the wire through. Where are you in Chicago?
Jack
www.picturetrail.com/topless57
ToddVanSlyke
Loc: Chicago Area
Reg: 09-26-07
01-15-08 03:10 PM - Post#1343363
    In response to Topless57
Thanks to you... and all... for info on the Pertronix unit. Sounds like a do-able job for this shadetree mechanic.
I live in Evanston, IL... just north of Chicago. Been here for 42 years.
triumphleroy
Loc: New Mountain Texas
Reg: 01-22-08
01-22-08 09:10 AM - Post#1348496
New to this forumn, but not new to Chevys!, and am wondering if the 1183 Pertronix is correct for the 1955 265? Wanted to install an HEI but there is a problem with oiling to this distributor if my old brain remembers correctly. My stock distributor has an oiler tube located on the side of the shaft.Ordered MSD small cap ready to run distributor, but think I remembered about this oiler problem on the 265s. Petronx says 1183 is right kit but they also told me only available in Petronix II ????? Thanks a bunch for any first hand knowledge!
ps, interesting question on the Overdrive also have several and plannig to install one in this little car.
Multiple Chevys from 1936 to 1972, Inlines, SBC. & Cummins powered 1949 Chevy One Ton Truck
Edited by triumphleroy on 01-22-08 09:33 AM. Reason for edit: No reason given.
01-22-08 09:56 AM - Post#1348529
    In response to triumphleroy
Yes, there is a unit for the 55-6 dist, but I don't know if the part number is 1183. Believe it or not, of all the ones that I've installed, I've only done one 55 dist and that was several years ago. Most installations have been on 57-74 style distributors.
Just to mention again, I much prefer the version with the magnet ring (1181). Yes, it is more time conduming to install this unit and also requires removal of the dist, but if nothing else, this also gives you an opportunity to clean, repair and shim the dist if needed.
beejay 82
Deceased Member
beejay
Loc: Pflugerville, Texas
Reg: 06-01-04
01-22-08 11:31 AM - Post#1348584
Welcome to CT. You will find that this place has the answers to your questions even before you know you have them. If you're going to do mods to your car, you can also check out the modified forum.
Oh, almost forgot. Where is New Mountain? Is it close to Old Mountain???
Bruce
http://www.picturetrail.com/beejay3/"
Edited by beejay on 01-22-08 11:32 AM. Reason for edit: No reason given.
triumphleroy
Reg: 01-22-08
01-22-08 06:14 PM - Post#1348825
    In response to beejay
WELL GUESS WILL JUST HAVE TO GET ONE AND INSTALL IT OR MODIFY IT WITH SOMETHING ELSE.
NEW MOUNTAIN IS NEAR EAST MOUNTAIN and WEST MOUNTAIN, COUPLE HUNDRED MILES NORTH EAST OF PFLUGERVILLE TAXES;nearLake O Pines, 10 miles to closet town 1/2 mile off of oiltop road.and these are all real towns in Taxes.
come on over and I'll show you my junk.
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
01-22-08 07:16 PM - Post#1348871
Thanks for bringing up the question re the oiler. Is there any way that these dists (bowl type, eg 891) can be retrofitted to eliminate the need to oil it? And, to really get of track, can the generators be modified to eliminate the need for frequent oiling? Don
bowtieollie
bowtieollie
Reg: 12-06-99
01-22-08 07:24 PM - Post#1348877
    In response to Highlander1
If you would like to stop oiling your generator with the oiling cups - you need to upgrade the bearings to SEALED type.
No more oiling required.
Distributor? You need to put a little oil in it from time to time.... There is no upgrade possible since it will not accommodate the felt to retain the oil - the later design had.
Petronix?? I am really surprised to read of all the positives with that system. I have heard nothing but problems and had to go rescue three of my GM buddies after an install.
So.... keep the points in the glove box - otherwise, you may not get home.
If it was "so good" I would have it in my vehicles - but I prefer to stay with points.
Bowtieollie
Chevytalk.com Moderator
01-22-08 07:49 PM - Post#1348896
    In response to bowtieollie
I put one of the original Pertronix units in a 67 283 distributor. Followed the instructions, shimmed it up the way they said - and it started missing within 5000 miles. The trigger wheel that mounts under the cap had a lot of runout and was damaged.
I don't know about the Pertronix II's reliablility good or bad. The only complaint I've heard is that you don't have fire until the ignition switch has been on several seconds.
Topless57
Topless57
Loc: Frankfort, Il.
Reg: 12-26-02
01-23-08 07:24 AM - Post#1349136
Ollie, I had heard that they did have some problems with the early ones, but I guess they fixed the problem. I haven't heard anyone complain in the last couple of years.
Jack
tmsnyder
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
01-23-08 08:46 AM - Post#1349163
Still wondering if the Pertronix system will work with an overdrive tranny......
01-23-08 09:24 AM - Post#1349197
    In response to tmsnyder
Are you talking about keeping the O/D automatic controls? The stock hookup momentarily grounds the coil (-) terminal during kickdown. I don't believe this should harm the Pertronix module, because the module grounds that lead every time the engine fires. However, this is a question I would want to ask Pertronix first just to head off any possible warranty issues. Try sending them an email explaining how the O/D works and please post back here with their answer.
tmsnyder
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
01-23-08 02:01 PM - Post#1349402
That's what I'm wondering. Now where's that schematic......?
57chevyeddie
Loc: Ga.
Reg: 09-15-04
01-23-08 04:45 PM - Post#1349529
I installed the Pertronx and it has performed very well for me. Be careful to set the end play as per the instructions. I believe this is what could cause a failure. It requires removing the distributor but its allows you to set that end play properly. You definitely won't regret it.
Fast Eddie
OverKnight
Loc: Central New Jersey
Reg: 10-29-04
03-17-10 08:04 PM - Post#1881945
I realized that I, too, never heard an answer to this question. I have a Pertronix system in my '57 Chevy 210 with the 235 six. I will be installing a manual OD transmission this year, and was concerned about burning out the Pertronix when the ignition is grounded when the transmission kicked down out of OD. I emailed Pertronix, and below is their response:
If you have a negative ground system then there won't be any problem with the kick down switch, however if this is a positive ground system, then e-mail us or give us a call at 800-827-3758.
Thank you,
Tech Dept
So, I'll give it a try. I still need to find a kickdown solenoid bracket for the six-cylinder engine, though...
"I shall pass through this world but once. Any good I can do, or any kindness that I can show any human being, let me do it now and not defer it, for I shall not pass this way again."
- Stephen Grellet
57CW
57CW
Reg: 05-25-08
03-17-10 10:40 PM - Post#1882023
Ollie, I am with ya and agree.
I been using the HD point set with the hole in the middle of one side of the contacts, helps in eliminating burnout. The '57 wagon 283V8 sb and my '72 Dodge MH 360V8 sb are equipped with this HD style, never had a problem with misfire yet. I prefer it the "stock" way, if it's not broke and running fine, why fix it or change it?
Jack-57CW
1957 Chevrolet 210 Townsman wagon
57EM - ELECTRIC MISTRESS
bowtieollie
bowtieollie
Reg: 12-06-99
03-18-10 03:43 AM - Post#1882058
    In response to 57CW
There ya go!
Over the years, I have always been able to get a vehicle back home with a bad ignition system and points.... but let the smoke out of the Petronix and she is gonna go home on a FLATBED.....
Bowtieollie
tmsnyder
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
03-18-10 06:48 AM - Post#1882110
    In response to OverKnight
Hi OverKnight,
I heard the same thing from Pertronix and it does work fine with the stock overdrive setup. The connection is to the "-" side of the stock coil, right? I've been running mine like that all last summer, no problem. The 'touch down' to pass or climb hills is a sweet feature to have and it works fine with pertronix.
Todd
Thank you,
Tech Dept
tmsnyder
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
03-18-10 06:52 AM - Post#1882113
What kickdown solenoid bracket? With the stock OD setup, there's a kickdown (KD) switch on the carb. And there's a solenoid on the OD unit on the tranny. Do you mean the switch bracket for the carb? I see those on evilbay from time to time, more common than the v8 version.
OverKnight
Reg: 10-29-04
03-18-10 08:07 PM - Post#1882572
Sorry, incorrect terminology. You're correct, I need the carburetor bracket for the kickdown switch, not solenoid.
I've looked everywhere (or, at least on eBay and Craig's List), but have never seen these bracketsm. The eight-cylinder brackets are reproducible, but not the sixes. If I had a good picture of one of these, I'd be able to recreate one. The picture in the Assembly Manual to too crude to be useful. If you find one, please let me know.
Thanks again.
- OverKnight
- Stephen Grellet
jkarthur
Reg: 03-17-03
03-19-10 07:27 PM - Post#1883112
I have a spare 6 cyl kickdown switch bracket . Let me know if you still need one.
Kerry in Mississippi
 Page 1 of 2 ALL12
Execution time: 0.279 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:52 PM
