Username Post: 92 350 SBC TBI - vortec heads        (Topic#177102)
The_Hunter
The_Hunter
Loc: Manitoba, Canada
Reg: 02-14-05
12-14-07 07:11 AM - Post#1318293
I'm on a quest for more mileage and power, am I on the right track here?
Currently my 350 is a bone stock 92 TBI engine, with the exception of the exhaust and tbi spacer.
Exhuast contains 3" dual pipe, dynomax ultraflows, and holley afterburner headers, 3" collector.
350 Vortec heads, any specific casting number you would suggest?
Intake. Will need something to match TBI unit to the vortec heads, does that exist?
TBI, Any gain to using the 454 unit? It flows at 670CFM instead of 550CFM (I think)
Felpro gaskets.
Cam swap, will need to match this combo.
I'm looking to make 275-300 HP at the flywheel.
86 C10 Short Box
Computers are like air conditioners - They can't do their job properly if you open windows.
racecar100
Reg: 09-04-07
12-14-07 08:29 AM - Post#1318334
    In response to The_Hunter
You need this Comp HYD Roller for good power and mileage.
HYDRAULIC ROLLER-Optimized fuel mileage Hyd. Hyd. 800 to 5000 08-525-8 TPX246HR-16 246 258 194 206 .470 .464 116°
12-14-07 09:03 AM - Post#1318361
Felpro gaskets.
GM Performance Parts makes an intake that lets you use a TBI on Vortec heads. Last I heard it was about $300. Often, people say Edelbrock makes one but last time I checked, they don't - people see the Performer that works on TBI engines and get confused.
The Vortec heads are a great upgrade over the TBI heads, but you'll almost surely need to do some custom chip tuning to have an engine that runs properly and gets the gains you're after, especially with any cam swap that differs significantly enough from stock to be worth the effort.
The_Hunter
The_Hunter
Reg: 02-14-05
12-14-07 10:25 AM - Post#1318439
    In response to someotherguy
Looking around on the net, it seems that vortec casting #906 is the "good" heads.
86 C10 Short Box
12-14-07 11:54 AM - Post#1318490
The 062 head is fine too. There was/is a myth going around about these being no good. The situation is that there were some 062 castings that were machined differently for HD trucks that are indeed no good because of the way they were machined (can't remember all the fine details). But this represented only a very small percentage (less than 1%) of all the Vortec heads produced for production trucks.
Maybe somebody remembers the details.
The_Hunter
The_Hunter
Reg: 02-14-05
12-14-07 12:41 PM - Post#1318522
    In response to Rick_L
http://www.gmpartsdirect.com/results.cfm?perfPacka...
Is that the manifold I need?
86 C10 Short Box
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
12-14-07 06:48 PM - Post#1318744
There is actually not a "BAD" vortec casting other than the 520s, which came on SOME of the earlier 305s. Even the 059s that came on the later 305s are good heads to have. The difference is not in the casting of the heads, it is in the angle of cut used on the exhaust seat of some of the HD 350 Vortecs (over 8,600 lbs GVW). The change in the angle was to allow for increased cooling of the exhaust valve by giving the valve more contact with the valve seat and giving greater cooling.
That being said, I have done the Vortec head TBI thing and it ran very well when done in conjunction with DIY Prom Burning.
GM made a factory TBI-Vortec intake with 2" bores, without EGR for use in Marine and Export applications. I had one at one point in time, but found even better performance with an edelbrock performer RPM Vortec intake manifold and a Marine TBI-Carb adapter.
If you were to switch to the 1993-1995 TBI PCM, there is even a factory GM 350 Vortec TBI calibration available as Memcal Broadcast Code BRDW.
GM BRDW CHEYENE 57 L V-8 Aut 1996 (pot) CHK:BC6E DELCO 2 Superchips BRDW CHEVRO~7POT 4103
GM BRDW CHEYENE 57 L V-8 Aut 1996 (pot) CHK:C8FF DELCO Superchips BRDW CHEVRO~3POT 4101
GM BRDW CHEYENE 57 L V-8 Aut 1996 (pot) CHK:B67D DELCO 2 Superchips BRDW CHEVRO~5POT 4102
GM BRDW CHEYENE 57 L V-8 Aut 1996 CHK:969B DELCO 27C512 16197427 BRDW CHEVR~82STD 4277
Edited by 1983G20Van on 12-14-07 06:55 PM. Reason for edit: No reason given.
rusty82silverado
Reg: 03-20-05
12-15-07 07:26 AM - Post#1318968
    In response to 1983G20Van
I hope your aware that drastically changing a TBI engine from stock means your gonna have to either re-tune the ECM yourself or have someone do it for you. Mail order chips are mostly crap.
The_Hunter
The_Hunter
Reg: 02-14-05
12-15-07 10:01 AM - Post#1319036
    In response to rusty82silverado
I am prepared to reprogram the ECM, that would be the "fun" part I think. (Once you know how to burn chips and have a good definition).
86 C10 Short Box
rusty82silverado
Reg: 03-20-05
12-15-07 10:11 AM - Post#1319043
Here is a good informative thread, it does not get much into the retuning aspect as he is paying to have someone else dyno tune it, but he builds a 383 TBI and you get to follow from start to finish.
http://www.thirdgen.org/techboard/tbi/420236- l05-3...
That forum is the best forum for the TBI I have come across, lots of good info. They have a whole section devoted to tuning the ECM's and PCM's, with info on converting from ECM to PCM and even adding a mass air flow sensor to a TBI, neat stuff.
A quick answer on your TBI/vortec intake question.... Yes GMPP and holley both offer vortech TBI intakes, you also could do a 4bbl intake with an adapter that most people do. From what I understand some very few vans and/or trucks came with vortech headed TBI engines in the mid 90's.
Edited by rusty82silverado on 12-15-07 10:15 AM. Reason for edit: No reason given.
1983G20Van
Reg: 11-13-02
12-15-07 10:22 PM - Post#1319496
TONS of MARINE 350 engines ran a TBI-Vortec head manifold with a 2" bore TBI unit as well. They turn up on the Ebay Marine section quite often.
Execution time: 0.371 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:21 PM
