Username Post: Holley 4 Bbl Leaking out Fuel Bowl Vents        (Topic#173824)
Gray Headed Mule
Gray Headed Mule
Loc: Fort Worth, Texas
11-03-07 02:19 PM - Post#1287764
I was cruising around today and the car started flooding out really bad! I've got a 350 330hp with a 600 cfm Holley Carb on it. Got it home (barely) and popped the hood, BAD smell of gas. Took off the air cleaner and the carb was smoking, not from fire but from gas being dumped into the engine. I tried starting it and the carb was spitting gas out the fuel bowl vents. I looked down inside the carb and gas was dripping out of the drivers side jet. I've got a manual fuel pump, no pressure regulator on the fuel line. Any hints? Float stuck? Would the float being stuck cause this? Too much fuel pressure? But why now? Thoughts?????
Mule
I'm sexy and I know it!
My 49 Chevy Fleetline Deluxe Restoration Project
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
11-03-07 02:44 PM - Post#1287775
    In response to Gray Headed Mule
If it's coming out the vents you have a needle/seat problem. Either trash or bad float. Pop the bowl off and take a look see. Do you have a fuel filter before the carb and after the fuel pump? Might check/replace it too and see if it is full of crud.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
Edited by fritz1990 on 11-03-07 02:44 PM. Reason for edit: No reason given.
beejay
Deceased Member
beejay
Loc: Pflugerville, Texas
Reg: 06-01-04
11-03-07 03:37 PM - Post#1287803
Wayne,
I don't know if this has ever been discussed on your setup or not. AND, I really didn't pay attention to the fuel line setup. Do you have a filter BEFORE the fuel pump? Or, do you have one AFTER the fuel pump. Personally, I prefer the "before fuel pump" situation. You've evidentally got some "trash" being pumped to the carb. This CAN skru upo the float mechanism, and hold the float down which will flud the engine. The rest of the stuff was good when you left after lunch on the 21st, so I really believe that's the problem. And, ya be skruin' up MY kar!!
Bruce
http://www.picturetrail.com/beejay3/"
Old_Longboarder
Deceased Member RIP Art
Old_Longboarder
11-03-07 03:42 PM - Post#1287808
    In response to beejay
If it's leaking out of both primary and secondary vents, it's crud in the needles and seats. If it's just leaking out of one or the other, the possiblity exists that there's a hole in a float and it's full of gas.
Hope for the prior scenario.
Home.., is where dog hair sticks to everything but the dog.
Limey Tri Chevy
Limey Tri Chevy
Loc: Hertfordshire, England U...
Reg: 10-19-05
11-04-07 03:39 AM - Post#1288033
Have the car at idle and tap the bowl gently with a pin hammer. This sometimes dislodges the crud temporarily go get you home safely. I always have a large canister type filter before the pump as this helps save the pump from gas station crud and a non restrictive one just before the carb. If your not flowing too much fuel those clear glass filters give you a good idea of whats still in the fuel. I don't ike the sintered bronze filters that holley put in the inlet so remove them as they can block very easily.
Also think about cleaning out your gas tank or draining it. I had a '49 Chevy with almost 1/4" of silt in it. Went like a new car after I cleaned it all out.
'57 Bel Air 4dr wagon
'57 210 2dr. 9.3 @ 155 mph 0-60 in 1.47 seconds
'55 Bel Air 2dr
'02 H/D Lightning
'08 Anniversary Custom 1200 Sportster
'30 Model A sedan
My pics
11-04-07 04:30 AM - Post#1288046
    In response to Limey Tri Chevy
Be careful when you put a filter in the suction line. A filter there needs to be rated for suction use. It would have a 100 micron or up rating - essentially a strainer. Otherwise it will be too big a restriction. Shop carefully for that type filter - most are not suitable. Most filters on the market are meant to be placed in a pressure line.
Steves32
Reg: 12-22-99
11-04-07 06:47 AM - Post#1288130
    In response to Rick_L
100 micron on suction side- 10-20 micron on pressure side. You need little to no resistance on suction side of any pump- electric or mechanical. Pumps aren't very good pullers & when you add the incorrect filter- your volume falls off the map.
Gray Headed Mule
Gray Headed Mule
11-04-07 12:13 PM - Post#1288349
    In response to Steves32
Thanks for all the replies guys! I never noticed but I don't even have a filter on my gas line! I bought the engine ready to bolt in place and fire up, never even noticed that it didn't have a filter. Looks like I better insatll one!
Mule
Anonymous
11-04-07 08:37 PM - Post#1288741
Mule,
There was a pretty good string on this not long ago when Anthony (Awendel) was having a similar problem. You might review that one for some tips.
Good luck,
56BUDDY
Loc: Union City, CA
Reg: 12-31-02
11-04-07 09:38 PM - Post#1288782
Mule,
Do you have the Chevy crate HO Deluxe engine? The one that's complete including a 600 Holley, long water pump, HEI dist, etc.,etc.?
If so, I've been having carb (Holley) issues myself. Found out that my float levels were too high. Mine was running rich, fouled a brand new set of plugs and I only have less than 2k miles on the engine! Kept hearing about Power Valves being blown out but, this is a brand new carburetor and I didn't want to panic and start replacing everything! Once I adjusted the float levels correctly the electric choke fell into place and the car has been running real smooth now.
Good Luck to you...by the way, I did add a fuel filter (after the manual pump) before I started the motor.
Mel
Mel
Ohio55
Ohio55
Loc: Shelby,Ohio
Reg: 10-29-06
11-05-07 12:21 AM - Post#1288808
What year 350 do you have? I had a mid 80's 350, 4 bolt main out of a truck in my Chevelle and I had that same problem. It turned out that the mechanical fuel pump I got from the parts store, that was for my specific year 350, was for a fuel injection engine and the overly high fuel pressure would eventually override the needle & seat on my holley and flood out through the vent tubes.
I put on a fuel regulator and the problem was solved.
I'm sure you could also change to an older year pump.
Good luck with your problem
1955 2dr 210 Sedan Link
beejay
Deceased Member
beejay
Reg: 06-01-04
11-05-07 12:44 PM - Post#1289146
    In response to 56BUDDY
Mel,
Holley fixed the Power Valve situation a few years ago. I have a Holley 600, adjusted the float level after many backfires thru the carb, and did not blow a Power Valve. Runs fine now, after all the adjusting I had to do. It's definitely NOT run-out-of-the-box.
Bruce
Execution time: 0.23 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:15 AM
