Username Post: 97 5.7L crankshaft position sensor problem        (Topic#164706)
turtleabel
Loc: utah,usa
Reg: 11-28-05
07-15-07 04:09 PM - Post#1208937
after driving for a while rpm guage goes crazy up and down rough ride can shift into nuetral and smooth out the rpm then throws code P0339 changed cks sensor to no prevail can anyone tell me what else could be wrong thanks
CDAUSA
Needs to Get Out More Member
Loc: Texas Panhandle
Reg: 12-31-01
07-15-07 04:23 PM - Post#1208944
    In response to turtleabel
Pull the wire connector back off the CPS, look really hard at those pins, use a light if you have to, make sure all are clean and tight. Pull on the wires firmly, but not hard enough to bend the lock. Corrosion in the wire end can cause this.
turtleabel
Loc: utah,usa
Reg: 11-28-05
08-02-07 02:25 PM - Post#1222851
    In response to CDAUSA
thanks cdausa i use some electrical cleaner on the plug and so far so good runs great again no codes being thrown thanks again
CDAUSA
Reg: 12-31-01
08-02-07 07:38 PM - Post#1223075
Good deal, keep us updated, hope it is fixed though.
Execution time: 0.271 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:54 PM
