Username Post: Rear mounts for coil over shocks        (Topic#160186)
gene
gene
Loc: In the Heartland, US of A
Reg: 05-09-01
05-21-07 12:29 PM - Post#1169819
I'm mounting some coil over shocks on the rear of the car. The mount I'm asking about is the upper one.
I've seen on some 2400# street rods they make an upper mount on the frame with a 1" diameter stock with a 5/8 hole for a 5/8 bolt to retain the coil over.
Is a 1" diameter sufficient for a heavier car like a tri-five chevy? The center of the eye of the coil over shock is 1 1/2" from the frame.
Is anyone using 1" diameter for the standoff, and do you have many miles on it?
Angle of the coil over is 15-20 degrees.
Thanks.
C4 Corvette narrowed front/rear suspension, C5 13" calipers/rotors adapted to C4, Viper differential with Intrax 3.54 ratio (the snake has been charmed!), stainless tubular frame, LS1 with T-56, chambered exhaust side pipes
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
05-21-07 01:36 PM - Post#1169866
    In response to gene
Gene, mine is probably over kill, but you asked:
Ohiosnows 57
Ohiosnows 57
Loc: N. Canton,Ohio
Reg: 12-17-03
05-21-07 02:00 PM - Post#1169884
    In response to Nick P
That looks NICE
-Brent-
57 Bel Air 2-door sedan - Sierra Gold & Adobe Beige originally V-8 PP & PG Trans - 1/16/04
57 GMC 150 (3/4ton truck) 347ci V-8 * 4-speed * long bed * small window - 3/10/06
patrick_rodgers
patrick_rodgers
Loc: Heart of the California G...
Reg: 07-18-03
05-21-07 02:13 PM - Post#1169894
    In response to Ohiosnows 57
Gene, this was discussed when 1sick57 had his issues with the shock bar being notched. There were some calcs run for ball park sizing.
1957 Sports Sedan and Nomad
2005 Subaru Legacy wagon (built in Indiana from parts made in the US)
gene
gene
Reg: 05-09-01
05-21-07 05:14 PM - Post#1170021
Nick:
That looks really nice.
Is the mount the bolt passes through 1" diameter, and are you using a 1/2" or 5/8" bolt?
gene
gene
Reg: 05-09-01
05-21-07 05:16 PM - Post#1170023
    In response to patrick_rodgers
Patrick:
I remember some of the discussion of 1sick57's problem, concerning the cross rail. I'll go back and review it concerning the mounting of the shocks themselves.
Anonymous
05-21-07 05:55 PM - Post#1170052
Nick,
That's inspiring!
Nick P
Nick P
Reg: 10-15-03
05-22-07 07:21 AM - Post#1170350
    In response to gene
Gene I am using 5/8" bolts upper and lower. Also, notice the additional brackets that have been added. I am certain that this setup will offer no issues.
Thanks Greg! Considering your ride and its quality, that means a lot to me.
Edited by Nick P on 05-22-07 07:22 AM. Reason for edit: No reason given.
puzzley
DECEASED "12th Year" Platinum Supporting Member
puzzley
Loc: Lexington, Ky
Reg: 02-21-04
05-22-07 08:29 AM - Post#1170422
Wow, Nick... That is some serious work... VERY impressive.
Carpe Diem, Vita Brevis - "Seize the day, life is short"
Execution time: 0.23 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:08 PM
