Username Post: setting timing on '91 v6 4.3 TBI        (Topic#159942)
jiiz
Loc: Finland, Europe
Reg: 02-17-02
05-18-07 12:12 PM - Post#1167818
Hi Guys,
I spent all day today trying to replace the distributor. That was first time replacing the dist and I managed to not the set the new one properly and started the engine. Heartbreaking noise and ignition setting gone... Finally managed to find TDC and put in the distributor with brother-in-laws's (who actually knows what he's doing). However, we didn't get the timing correct (drove it and it hardly took off from red light. When rpms got little higher felt better). There's no stickers under the hood (export model, that might be the reason), so we tried to hit 0. But if we unpluggeed this wider (with 4 connectors, I think) cable from dist, the engine died right away and wouldn't start over. If we took off the other connector with 2 wires, no start.
What needs to be done to set timing no '91 4.3 v6 manual W/T1500?
Any help appreciated, since supposed to drive to work to pay for the new dist. Thanks!!
jiiz
chrisk1500
chrisk1500
Loc: Saskatchewan, Canada
Reg: 10-30-04
05-18-07 12:28 PM - Post#1167829
    In response to jiiz
Disconnect the timing wire....tan/black....usually in the big wire bundle on the firewall or behind the glovebox....
07.5 DMAX 2500 HD ext cab, 4x4, Edge EVO Race, 4" straight pipe, PPE tie rod sleeves, bushwhacker pocket flares, etc...13 second farm truck!
06 Escalade
15 Sierra - Kodiak Edition
Chevytech
Chevytech
Reg: 04-25-04
05-18-07 06:21 PM - Post#1168026
    In response to jiiz
I believe this information to be accurate for your 1991 C/K truck:
To set the timing you must unplug the set timing connector, which is a single Tan wire with a black stripe/tracer on it.
The set timing wire is located, under the hood, on the main harness that goes from the engine to the firewall, on the passenger side, underneath the black plastic cover (if it’s still there) that covers the junction block, relays & fuses. It’s near the top usually on the back side of the harness. Doing this will set a code 42 in the computer. Clear the code after you are done checking or setting the timing.
jiiz
Reg: 02-17-02
05-19-07 07:57 AM - Post#1168266
    In response to Chevytech
Thanks guys! Got the timing set with the new dist. My truck's running better than ever before now. You literally gave it life extension for years to come since we do not have too many shops here that know how to fix US made cars and everything's more or less DIY.
Your instructions were perfect. Thanks!
jiiz
Chevytech
Chevytech
Reg: 04-25-04
05-19-07 10:37 AM - Post#1168371
    In response to jiiz
Thanks for the feed back.
Glad it worked out.
Execution time: 0.248 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:12 AM
