Username Post: Elgin cams        (Topic#152523)
awendel
awendel
Loc: 25 miles south of Houston...
Reg: 01-12-03
02-24-07 01:42 PM - Post#1104204
Anyone here heard of or had an Elgin brand cam?
Anthony
My car page
Proverbs
11.21 Be sure of this: The wicked will not go unpunished, but those who are righteous will go free.
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
02-24-07 01:52 PM - Post#1104213
    In response to awendel
Now with the aid of a computer, Dema makes his own camshaft designs. His customers include General Motors, Ford Motor Co., Nissan Corp., Zakspeed International, Porsche Motor Sports, and "Winston Cup" engine builders. He has the largest percentage of cams used at "Mid-Ohio" from GT-1 to Formula-V.
five-seven
Loc: new jersey USA
Reg: 11-01-05
02-24-07 01:54 PM - Post#1104214
Awendel,
I had an elgin cam that was a repop of the old fuel injection 327 cam and had no trouble with it. That was 15 or 20 years ago so I cant tell if their quality is the same now. Steve
RSB
RSB
Loc: San Jose, CA, USA
Reg: 06-21-00
02-24-07 04:36 PM - Post#1104304
I have the Elgin E923 in my 283. Runs good.
Lift: .420"/.443" Duration @ .050": 204/214 Lobe Center: 112
Ron
Steves32
Reg: 12-22-99
02-24-07 04:40 PM - Post#1104309
    In response to RSB
I had one in a previous motor I built when I 1st bought the car. No troubles at all.
awendel
awendel
Reg: 01-12-03
02-24-07 05:21 PM - Post#1104340
    In response to Steves32
Thanks guys
Been trying to decide on a blower cam and Elgin has one with the specs I'm looking for and it's quite a bit less than any of the name brands I've looked at. They may go to the head of the list.
Anthony
My car page
Proverbs
02-24-07 05:59 PM - Post#1104377
Elgin is not a big retailer - most of their stuff is sold by others, and under various brand names.
For instance, it's possible and likely that the cams you see from Summit or others as "house" brands are made by Elgin.
So while they're not a "name" brand, they are a "name" supplier, and they are a US company that's been in business for some time.
I wouldn't worry about its quality. Make sure it's what you want and check valve to piston clearance as well as retainer to guide and all the others.
awendel
awendel
Reg: 01-12-03
02-24-07 07:15 PM - Post#1104439
    In response to Rick_L
Rick
I've been doing some measuring with my dial indicators and degree wheel with my heads on the block. Using the opening and closing specs on the cam it looks like the one Lunati recommended will be ok as far as the piston/valve clearance. Of course I won't know for sure till I get one installed and check it then.
Anthony
My car page
Proverbs
Thadd
DECEASED Member
Thadd
Loc: Rolling Hills, Ca,
Reg: 12-30-01
02-25-07 02:46 PM - Post#1105120
My machine shop (El Inca Racing-LA) is a dealer for Elgin. I have used a few of their cams, and we recently put one into my S-I-L's 383...nice cam, pulls hard at bottom and mid range
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
02-25-07 10:27 PM - Post#1105473
    In response to Thadd
Many, if not all, of their cams seem to be the same as those sold by Summit Racing, Jeg's, Federal Mogul, and others. (194/204, 204/214, 214/224, etc.), which at one time were all made by Camshaft Machine Co.
I'm surpirsed to hear that Elgin actually makes parts in the U.S. anymore. I bought some Elgin ball joints and tie rod ends many years ago that were made in Mexico. The rubber boots split open within a few weeks, tie rod ends wouldn't take grease, etc. Sent all the parts back and bought Moog instead.
awendel
awendel
Reg: 01-12-03
02-26-07 08:48 AM - Post#1105685
    In response to MikeB
I just found out there are two companies named Elgin ,and both make cams. That's going to get a little confusing.
Elgin Industries
Elgin Cams
Which one is better?
Anthony
My car page
Proverbs
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
02-26-07 09:43 AM - Post#1105713
  • awendel Said:
I just found out there are two companies named Elgin, and both make cams. That's going to get a little confusing. Which one is better?
I'd say Crane, Comp, or Lunati.
What size/type cam are you interested in? You might want to call the folks at D. Elgin Cams to see what they recommend, since they don't list any of their cams. Interesting philosophy, actually. The other Elgin company (Elgin Industries) looks like the one that imports cheap suspension parts and sells generic cams.
Edited by MikeB on 02-26-07 09:53 AM. Reason for edit: No reason given.
awendel
awendel
Reg: 01-12-03
02-26-07 12:22 PM - Post#1105856
I'm thinking the same thing now. The Elgin cams I was looking at are from Elgin industries. If they are imported, thats why they were so much cheaper than the name brand cams. Think I'll stick with the name brands rather than take a chance on getting an import.
I need it for the 454 blower motor I'm building. I've got a range of specs I'm looking for and just need to make a decision on whose cam I want. Nothing radical, just blower friendly.
Anthony
My car page
Proverbs
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
02-26-07 12:33 PM - Post#1105863
Just a tame little 454. huh?
I think you should call a few manufacturers to get their recommendations.
Thadd
DECEASED Member
Thadd
Reg: 12-30-01
02-26-07 12:59 PM - Post#1105875
Not to beat a dead horse , but Elgin (Elgin Industries) has been in the OEM business for many many decades. They provide the OEMs with a lot of parts. I don't think that characterisng them as some guys who import a bunch of cheap stuff does them justice.
I have no stake in this topic, but they have been around longer than most of the big cam grinders like Crane and Comp, and produce a lot of camshafts....
FWIW, when it came time to buy a cam for my blower motor, I went with Crower, based on past racing experience...I run their cam, lifters, push rods, springs, and SS rocker arms because of their reputation for reliability, and the excellent service when I have called them in the past.... I lost a needle bearing on a rocker arm in the race car, and they replaced all 16 rockers gratis...They had me send the old parts because they had not had that part fail before...
I also agree picking a cam company and calling for their recommendation....
Nick P
Nick P
Reg: 10-15-03
02-26-07 01:02 PM - Post#1105878
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
02-26-07 01:56 PM - Post#1105936
Right or wrong, I associate Elgin with low end, imported, replacement parts sold by JC Whitney. Their website says they have a modern plant in Illinois, so maybe they make some good products, too. Do they really grind their own cams?
awendel
awendel
Reg: 01-12-03
02-26-07 02:17 PM - Post#1105956
Thadd
Are you saying the cams from Elgin Industries are not some import cams? If so, I'll go back to looking at them again. Their costs is pretty good compared to some others. I did get recommendations from Lunati and Crane, but when I saw the Elgin cams were cheaper for the same specs I thought why not check them out too. The other Elgin cams is in California. It looks like they will custom grind you a cam instead of choosing something from a catalog. Here's a link to the cams I'm looking at. Competition Products
Anthony
My car page
Proverbs
Tip
"6th Year" Gold Supporting Member & Chatroom Supporter
Tip
Loc: Texas-Nose in the Corner
Reg: 08-31-02
02-26-07 07:11 PM - Post#1106227
My experience is you can't use "Good" and "Cheap" in the same sentence discussing cams...Its either "Good" or its "Cheap"...one or the other!! I'd go with a name brand but then I'm lazy and hate the minutia when several are so close in numbers!!
Bob
www.picturetrail.com/TigerTip"
02-26-07 07:41 PM - Post#1106254
    In response to Tip
Tip, where I work we give the boss and the others who need things a checklist - good, cheap, and quick - we will go for 2 out of 3 but only usually achieve one.
Tip
Tip
Reg: 08-31-02
02-26-07 07:49 PM - Post#1106270
Good point Rick...very good point!!
Bob
Glenn_McAtee
Reg: 06-20-01
03-04-07 05:06 PM - Post#1111195
    In response to Tip
FWIW I put an Elgin cam, lifters and timing set in an old work car years ago, got the engine out of it back a few years later after a friend used the car up. It's a 400 SBC out of a '74 Monte Carlo and is sitting out in the garage right now and will eventually end up in my "new" '76 Monte Carlo. Cam, lifters and timing set are still good and will probably get reused in a demo derby car my kid has. Not sure I'd put their stuff in a blower motor but for a daily driver it's just fine. We've used quite a few Summit cams too and never had a lick of trouble with any of them.
Execution time: 3.87 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:21 AM
