Username Post: Aluminum vs. Cast Iron PowerGlide        (Topic#144790)
Anonymous
11-21-06 11:42 AM - Post#1037761
A mechanic told me my '55 sedan has an aluminum powerglide tranny. That brings up several questions. Help on any appreciated:
--Does that mean my car doesn't have the original tranny?
--What year did Chevy replace the cast iron PG with the aluminum PG?
--Does replacing a cast iron PG with an aluminum PG affect drive shaft length?
Royer
Needs to Get Out More Member
Loc: Bloomfield Hills, Michiga...
Reg: 09-25-01
Re: Aluminum vs. Cast Iron PowerGlide
11-21-06 11:53 AM - Post#1037762
    In response to MrMudBay
The cast iron case Powerglide was used on the Chevy cars and trucks with the 6-cyl. 235 cubic inch engine through the end of the 1962 model year. On V8 equipped Chevys, I believe the aluminum case PG came in around the beginning of the '62 model year. An aluminum case PG is definitely not original on a '55-'57.
I'm not certain about the overall lengths, but I believe they are the same - so no driveshaft change would be required.
Royer
67SS427
67SS427
Loc: Lawrenceville, GA, USA
Reg: 05-26-01
11-21-06 12:25 PM - Post#1037763
In addition, while the driveshaft can still be the same length, the front yoke is not the same. The 55-57 powerglide uses a coase splined yoke, while the aluminum powerglide uses a fine spline yoke, like a Turbo 350.
Other than not being original to the car, I think the aluminum powerglide is a better transmission and I'd rather have it than the iron one, if given a choice.
Also, of course, the aluminum powerglide has the later shift pattern, which is different from the 55-57 automatic shift pattern.
An unlikely possibility would be that you have an aluminum TurboGlide too, which was newly available in 57 and lasted thru about 61. Again, it was not used in 55/56 originally though.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-21-06 12:41 PM - Post#1037764
Is it an aluminum PG or did some one install a Turbohydramatic 350 or 400 in it?...The PG will up-shift once and the TH twice.This would be a more common change over.The performance and shifting characteristics of a cast iron and aluminum PG are about the same but the aluminum is about 80 pounds lighter.
Anonymous
11-21-06 01:17 PM - Post#1037765
    In response to 67SS427
SteveF -- Is the later shift pattern P R N D L? My car has the P N D L R pattern so maybe it is an original cast-iron PG.
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
11-21-06 02:57 PM - Post#1037766
A cast iron power glide does not have a removeable pan. I'm not an expert in Aluminum glides but I believe they all do have a removable pan. That may be a quick way to tell. Also if you just get under there with a flashlight, it's not hard to tell the difference between aluminum and cast iron.
If someone else can design it, I sure as heck can figure out how to fix it!
11-21-06 03:16 PM - Post#1037767
PNDLR would be a cast iron Powerglide.
Aluminum 'glides do have a removeable pan. It's rectangular and wider than it is long. A TH350 also has a rectangular pan but it's almost square with a big chamfer on one rear corner.
67SS427
67SS427
Reg: 05-26-01
11-21-06 03:43 PM - Post#1037768
Yes, the later ones are PRNDL. Sorry for stating the obvious, but you may have the PNDLR on your dash indicator, but does it work that way? Does your reverse actually function in the far right position?
Coley
Loc: Milledgeville, IL. 61051
Reg: 11-23-00
11-21-06 08:17 PM - Post#1037769
Only the 1964 and up Chevelle aluminum glide will fit in a tri 5, as it is the same length as a 5/6/7 iron glide, or 4 speed or overdrive,(uses same driveshaft length).
The cast iron trans was used by both the 283s and 235s thru 1962.
The aluminum glide came out behind the new 327 in 1962.
They were shorter, just as the 1958/62 iron case trans was shorter than the 5/6/7s.
Not sure of the length of the Chevy IIs, but they were air cooled.
Any man that thinks he is too old to learn new things, probably always was....
11-22-06 04:09 AM - Post#1037770
    In response to Coley
All the aluminum Powerglides from 65 and up had the long tailshaft, including full size and Chevy II. Only the 4 and 6 cylinder Chevy II Powerglides were air cooled. There may have been some other 6 cylinder models that were air cooled also. By far the most common cores for aluminum Powerglides are the long shaft models, and most are not air cooled. You can tell an air cooled unit by the big holes in the bellhousing for airflow, and of course they don't have the cooler line fittings on the side.
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
11-24-06 10:30 AM - Post#1037771
Strange...When I bought my 55 it had a 57 283 and and a 62 glide all mounted stock positions. When I resotored and installed the 265 and iron glide, I used the same drive shaft....
11-24-06 12:19 PM - Post#1037772
    In response to brad_bb
If it was indeed a 62 trans, someone must have swapped out the output shaft and tailshaft housing for a 55-57 one. I don't even know if it can be done, but it is commonly done on later transmissions.
jeffs55
jeffs55
Loc: Shelby Forest, Tennessee
Reg: 01-05-06
11-24-06 05:42 PM - Post#1037773
    In response to Rick_L
The first 55 I had I put a 327/aluminum PG out of a 65 Impala in it. My Dad (machinist at the time) made me a new plastic plate to replace the dash insert and I used rub on lettering for the PRNDL. The biggest problem I had was: the engine used the stock front mounts and I had to add a crossmember for the trans mount. This made the engine rock easily. As some of you may know, when the engine torques it can jam the throttle linkage, scarey!
I used a turnbuckle on the engine to the upper A arm bolt.
This broke a couple times. I eventually put a small length of chain to limit the engine rock. Hey, I was 16 or 17.
Does your trans mount at the fire wall or at the tail?
That's another tell tale.
Jeff
55 Handyman
66 F100 project
32 3 Window Coupe project
1948 Studebaker Champion
1977 Toyota Celica Coupe
2000 Blazer 4X4
My Pics
Coley
Reg: 11-23-00
11-24-06 08:09 PM - Post#1037774
They would have to have changed the tail shaft and housing from a later alum glide. Nothing on the housings will change from an iron to an alum.....
OR it might not have been a 1962....
11-25-06 03:32 AM - Post#1037775
You're right, I was thinking cast iron glide, which apparently was last used in 61. The aluminum and cast iron pieces obviously would not mix.
11-25-06 07:41 AM - Post#1037776
A 62 283 or 235 could still have a cast iron PG. Only the 327 (or a Chevy II) would have had an aluminum PG in 62.
Coley
Reg: 11-23-00
11-25-06 06:33 PM - Post#1037777
Cast iron were used through 1962, but only on the 235 and 283...
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
11-30-06 02:21 PM - Post#1037778
So what did he actually have in his car??
Execution time: 0.379 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:55 PM
