Hellwig Products IncPerformance Rod & CustomCold-Case Radiators
Octane Lighting
Username Post: Timing a 1985 305        (Topic#138269)
Jugg3rnaut
Loc: Mannheim, Germany
Reg: 03-29-05
08-16-06 08:09 AM - Post#986422
I'm looking for information on timing my 85 Blazer's 305. I'm in Germany so using a computer is out. How can I add timing marks to the harmonic balancer without dismantling the engine?
LMC Truck
Slonaker
Slonaker
Loc: San Antonio, TX
Reg: 11-26-01
Re: Timing a 1985 305
08-16-06 02:32 PM - Post#986423
    In response to Jugg3rnaut
You don't need a computer, just a timing light. There is a notch in the harmonic balancer that will line up with the timing tab on the timing chain cover. I think you look straight down behind the water pump on the 305 to see the marks on the tab.
It helps to clean up the balancer and the tab and make a white mark on the notch to make it stand out. I usually use chalk or liquid paper.
Slonaker
'86 Chevy C10 Silverado See it here or here.
N8sToolz
N8sToolz
Loc: N 42° 53.290' W71° 34.1...
Reg: 10-23-03
08-20-06 06:39 AM - Post#986424
    In response to Slonaker
if you cant find any timing marks, advance the timing until it pings, then back it off a bit, drive and adjust as necessary. Thats how i have to do it since my timing tab is MIA.
1982 Chevy K20 Converted from C20.
355/700R4
2002 Yamaha XVS1100CL VStar
2002 S10 2WD
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
08-20-06 07:41 AM - Post#986425
    In response to N8sToolz
There WILL be a timing mark on the damper (ALL, ALL, ALL stock or modified SBC dampers have them). If the motor has been apart, the reference mark on the timing cover COULD have been removed, but it usually isn't likely.
It may not be in a place where you expect it. Look on both the drivers side and passenger side for a reference timing mark (sometimes they are a little round piece of steel like a bullseye sight). It may be a little buried a little bit under pulleys and belts.
When you change the timing - if it has ESC or a fuel injection system - you need to unplug the timing reference sensor on the distributor that goes to the CPU. Otherwise the computer will just back out the timing changes you just made. Once you have made your timing changes, then plug the timing sensor wire back in.
Jugg3rnaut
Reg: 03-29-05
08-25-06 11:16 AM - Post#986426
I should have been more specific. There are no timing marks on the balancer, nor timing tab anywhere on my engine. There is a tube attached to the timing cover, right behind the water pump. Its for a magnetic sensor on a SUN Machine to be placed. I would so much like to convert to timing light marks, but how?
N8sToolz
N8sToolz
Reg: 10-23-03
08-26-06 02:48 AM - Post#986427
Then you will have to change the cover and the balancer. Ther will have markings as they are all the same standard.
355/700R4
2002 S10 2WD
Slonaker
Slonaker
Reg: 11-26-01
08-26-06 08:42 AM - Post#986428
On my 305 the timing marks were there with that tube. I would be willing to bet that you will find the mark on the balancer if you clean it up. It is just a little dent or notch in the edge. It look s like someone bumped it with a file.
Slonaker
GreyScar
Loc: South Cackalackie
Reg: 08-27-06
08-31-06 10:29 AM - Post#986429
I didn't think fuel injection started till 87, Get no.1 cyl. at TDC on compression, Get a flash light or something and check the 1 o'clock position on the dampner, there should be something there, That tube behind the water pump and mounted on the timing change cover is a bullseye as stated in the 1000 or so I've seen, Might be something different across the water.......
Senior Chevytalk Moderator
09-03-06 05:26 PM - Post#986430
Welcome to the site.
Read all the articles under the Ignition section here.
BTW - I run my 305 at 4 degrees. Do you have a vacuum guage? I tune my truck at idle this way.
LMC Truck
Execution time: 0.597 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:45 PM
