Username Post: Spark Plug Gap On Race Motor        (Topic#136978)
Badss350
Badss350
Loc: Lumberton,Texas
Reg: 01-01-01
07-28-06 03:34 PM - Post#976436
468 BBC, alcohol injected, .722 lift cam, MSD7AL3, 8MM plug wires, NGK plugs...they came gapped at .030...seems a tad low on gap to me?
Distant Thunder Cold As Stone A V-8 Screams Down From Its Throne One By One Each Car Succumbs When Something CHEVY This Way Comes
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
Re: Spark Plug Gap On Race Motor
07-28-06 07:09 PM - Post#976437
    In response to Badss350
Usually the widest gap you can consistently and reliably fire with your ignition system. .050 is usually a good starting point.
IgnitionMan
Reg: 04-15-05
07-29-06 05:35 PM - Post#976438
    In response to Vaughn
Obviously a high compression engine package.
The higher the comp ratio and cylinder pressuyres, the TIGHTER the plug gap needs to be, even with an MSD box helping the thing.
I'd try the .030 to start with, and if it sputters on the top end, drop the gap. .018 is about the practicle limit on a blown alchohol engine, .022 is getting right down there on a normally aspired one, and if the tighter gap doesn't help, fix the injectors.
Badss350
Badss350
Reg: 01-01-01
07-29-06 08:44 PM - Post#976439
    In response to IgnitionMan
Thanks, we set them at .030 tonight, ran 8.42 all night, very consistant...and yes, very high compression engine, JE 13:1 slugs..the injectors are brand new, we bought the Rons Terminator set up for alky....I think with a little tuning like going to 36 on the injectors instead of 35, playing with returnpills to get correct EGT, we can run some 7`s in the 1/4..but we ran 5 runs at 8.42x..first run was 8.54 but the first run is always slow for us...I read where NGK comes pre gapped at 30, just have to pick the correct heat range..As always, THANKS for the info!
Vaughn
Vaughn
Reg: 08-08-04
07-30-06 06:55 AM - Post#976440
Dave, wouldn't running more voltage to his ignition system help him to run more gap in this situation? Bigger gap usually means better flame front in gas motors - but alcohol may be different (I have limited experience with pure alcohol motors).
IgnitionMan
Reg: 04-15-05
07-30-06 05:20 PM - Post#976441
It's called ignition system compression resistance, or, the ability of the added cylinder pressure to blow the flame out.
Remedy, tighten the plug gap.
Execution time: 0.229 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:19 AM
