Username Post: REAR SPRING POCKET KIT        (Topic#121536)
DONZIE53
Reg: 11-22-05
01-14-06 04:57 PM - Post#853845
Are there any drawbacks are things to be aware of using the rear spring relocation kits offered by classic chevy international.
DONZIE
mokicruz
mokicruz
Reg: 12-11-04
Re: REAR SPRING POCKET KIT
01-15-06 03:45 AM - Post#853846
    In response to DONZIE53
There were so many posts with pictures on the subject last year I did it with out a kit. It was easier that I thought it would be. Some even posted the measurements. I had them in word pad but must have deleted them Cuz they are gone.
01-15-06 04:48 AM - Post#853847
    In response to mokicruz
If your doing it for tire clearance the wheel tubs are almost in line with the outside of the rear springs. The tubs will have to be widened also.
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
01-15-06 04:49 AM - Post#853848
I have the drawings if you have the skill or someone that can make the parts.
55rustbucket
Reg: 01-25-04
01-15-06 06:06 AM - Post#853849
    In response to Nick P
correct me if I am wrong or not but I heard that as long as your going to be (like me) running airshocks in the backend) I am not going to lower the backend at all on my 57. I am moving the springs inside of the framerails. I was told as long as im ot lowering the car any I can run a wider tire under the car without widenign the fenderwells. I still might end up widening them and mini tubbing the car anyways. I am going to be running a 13inch wide tire. Please let me knwo if i need to mini tub the car or not.
thanks,
Jimmy
1955 chevrolet 2door hardtop belair 1955 cevrolet 4door partscar 210 1956 chevrolet 2door sedan 150 1956 chevrolet 4door sedan belair 1957 chevrolet 2door sedan belair
55 stubby
55 stubby
Loc: Minnesota
Reg: 07-25-04
01-15-06 06:06 AM - Post#853850
I made my own. a frend let me look at his and mesure it. you will need to find bushings for the rear part so you know what size of pipe to use.The pockets are made from 3
" x 5" rectangler tube 3/16" it is easy if you have one to study. GOOD LUCK
rj_ly
Loc: Southwestern OH
Reg: 11-15-02
01-15-06 04:05 PM - Post#853851
    In response to 55rustbucket
Jimmy,
For years a popular thing was swapping the leaf springs and hangers side to side so the springs could be mounted inside the frame rails. I know people who di this to their Classics in the early 1970s.
It means removing the spare tire well.
You should be able to get 255 or possibly a 275 size tire inside a stock '57 quarter without mini-tubs or whacking the quarter panels open.
You also need to realize a LOT of this depends on backspacing of the wheels used that there.
57 Hrdtp(mine for 40 YEARS JULY 12)
57 210 4-dr Sdn(37 yrs Aug 12)
57 Hrdtp(32 yrs Jan 12)
57(windowed)S. Delivery(31 yrs Oct 12)
57 150 Wgn(24 yrs Mar 12)
57 210 2-dr Sdn(8 yrs Oct 12)
Pistol
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
01-15-06 04:17 PM - Post#853852
Without doing any minitubs or moving the springs you can fit a 274x60x15" tire with a 4 1/2" backspace,if you put in a pocket kit and mini tubs you can really go wild,both the minitub and spring move must be done,if you do just one then its pretty much meaningless
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
busyguy8
busyguy8
Loc: SF Bay Area, CA
Reg: 11-21-04
01-15-06 04:36 PM - Post#853853
    In response to Pistol
a few things here.. I'd like his questions answered about whether there are any drawbacks.
I've currently got 255/60/15 with 4.5 backspacing on 15x8 wheels on my stock with stock rear, no minitub, and no relocation of springs. I've done this on two cars, 57, and 56.
I can tell you clearly that the springs are the limitation to some extent. I've heard of folks on here that have gotten 275's even 295's on their car by relocating the springs without mini tubbing. This contradicts some of what you folks are saying, any clarifying of this?
-b
Aquired a '56 2dr hdtp BelAir on 6/9/05!
Link to my pics!
-bill
cktasto
Loc: Pleasanton, California
Reg: 12-25-05
01-15-06 05:46 PM - Post#853854
    In response to busyguy8
Hey busyguy,
I have 295s on my 56 without tubs, but the rear end (ford 9") has been narrowed, and springs moved inside the frame. They are REALLY tight but are not rubbing. I plan on tubing the rear to get bigger tires and to lower her down. Hope this helps.
Pistol
Pistol
Reg: 11-11-02
01-16-06 01:42 AM - Post#853855
275x60 15x8 4 1/2 backspace no tubs no spring relocation,I dont think a 295 will fit in mine,maybe with a spring move and a 5" backspace it might go,a spring move without tubs will only give you an extra 3/4"
Pete
01-16-06 02:07 AM - Post#853856
I would think that getting a 295 tire under the car without tubbing would be very tight on the ones that could and it wouldn't even work on some cars, but you'd almost certainly have to move the springs. Some won't even take a 275 with the stock springs, some will.
Another thing that hasn't been mentioned is that if you do a pocket kit and want tailpipes out to the bumper, you need to get rid of the spare tire well and center the gas tank.
The biggest drawback I can think of to a pocket kit is that it would be a nasty dirty job cutting and welding the pockets on a car that has the body on the frame. This is so much easier to do with the body off, I'm sure glad mine was. Of course that goes for any frame/suspension mod.
asbicca
asbicca
Loc: Southern California
Reg: 07-18-03
01-16-06 05:23 AM - Post#853857
I have 275/60 15 BFG's on my wagon with an early Nova 8.2" rear end which is 57.75" wide. The wheels have a 3.75" backspacing, 8.5" wide, and the tire was very close to the side of the spring. With a .250" spacer everything fits great. I am in the process of building another stock frame with Earle Williams Motor, Trans, and rear shock mounts, along with a spring pocket kit.I picked up an early ford wagon 9" rear end which is 57.25" wide and I think that with the same wheel I should be able to fit a 295/50 15.
http://s2.photobucket.com/albums/y40/asbicca/55 %20...
rj_ly
Reg: 11-15-02
01-16-06 05:55 AM - Post#853858
    In response to asbicca
I've got a 245/60 on the back of my pink/white Hardtop with a 4" back spacing Cragar SS wheel and could get away with running a 255 tire.
Execution time: 0.247 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:25 AM
