Username Post: Rochester BC automatic choke        (Topic#121238)
hobbyjp
Reg: 12-25-05
01-10-06 08:17 PM - Post#851467
I have a 1954 210 with a 235.I have a question as to were does the automatic choke wire go to after it leaves the carb. Thanks for ahead for the answers.
roland67
Loc: France
Reg: 12-30-02
Re: Rochester BC automatic choke
01-11-06 12:35 AM - Post#851468
    In response to hobbyjp
Give your email and I will send you the pictures from the BC with linkage.
Roland 54 Bel Air 4D sedan 54 3100 4 speed
hobbyjp
Reg: 12-25-05
01-11-06 09:22 AM - Post#851469
    In response to roland67
My email address is hobbyjp@gmail.com thanks for the post.
jgalt
Loc: Huntsville, Alabama
Reg: 09-30-03
01-11-06 09:31 AM - Post#851470
Do you mean the TUBE that connects to the automatic choke? My BC carb has a tube that runs from the carb to the exhaust manifold. The tube opening rests on the manifold and a metal plate holds the tube in place.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-11-06 10:36 AM - Post#851471
There is no choke wire if it has an automatic choke???????????
hobbyjp
Reg: 12-25-05
01-11-06 10:54 AM - Post#851472
    In response to Gene_Schneider
there is a wire connector on the rochester BC that connects to something. I just dont know where it goes.
Royer
Needs to Get Out More Member
Loc: Bloomfield Hills, Michiga...
Reg: 09-25-01
01-11-06 11:33 AM - Post#851473
I believe that you have a carb - or at least an automatic choke assembly - that isn't stock. aof all the Chevy sixes from this general period through 1962 I've never seen any with electric choke heater elements. Electric choke heating elements were seen on carbs used on other makes however, so I suspect that's what you have.
Royer
hobbyjp
Reg: 12-25-05
01-11-06 12:15 PM - Post#851474
    In response to Royer
Reading the side of the carb it say’s Rochester BC. I know I have not been able to find an exact picture of my carb with this electrical connection. So is that what I am possibly looking at, a heater element? If so is it necessary to reattach this connection? I will post a picture later when I'm with the car.
2blu52
2blu52
Reg: 03-12-02
01-11-06 01:43 PM - Post#851475
It appears that some one has replaced the stock choke control with something of a later model that happens to fit in the space provided. As others have said the BC did not have an electric heat element as a stock item. I can forsee all kinds of difficulty in attempting to get the choke to operate properly with this combination.
THOMAS JEFFERSON
hobbyjp
Reg: 12-25-05
01-11-06 04:03 PM - Post#851476
    In response to 2blu52
[image]http://www.bannerautoandcycle.com/images/carb.jpg1[/image]
[image]http://www.bannerautoandcycle.com/images/carb.jpg2[/image]
[image]http://www.bannerautoandcycle.com/images/carb.jpg3[/image]
Here are the pics of the carb. Now that I actually look at it I dont think its a BC. Maybe someone told me that and I went with it. If anyone has any ideas of what it is please let me know. I'll try and look for some numbers off it to google.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-11-06 05:03 PM - Post#851477
Its a BC-I don't see a hot air pick-up tube running down to the exhaust manifold.This is a must.It connects to a choke stove (tin cover) that is clamped around the exhaust manifold.If the stove is missing I believe that NAPA sells a substitute.You can make a line (steel tubing).
hobbyjp
Reg: 12-25-05
01-11-06 08:23 PM - Post#851478
I have tried to find something on the Rochester BC-I but I have not been unable to find anything. Is their a certain year that this carb was used or a specific number? My carb no loner has the tag. Also I still do not know were the electrical connection goes or the hot air pickup.
roland67
Loc: France
Reg: 12-30-02
01-12-06 12:44 AM - Post#851479
OK have send the picture
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-12-06 06:52 AM - Post#851480
There is NO eletrical connection running to the carb. or the choke.The exception would be if some one would have replaced the hot exhaust heated air choke cover and thermostatic spring with an eletriaclly heated unit.I have never seen such a thing available for a 6 volt system and a Rochester carb.
The BC or automatic choke Rochester was used from 1952 up into the '70's.
khardy
khardy
Loc: No Longer at sea. Sailing...
Reg: 12-17-99
01-12-06 07:29 AM - Post#851481
Hi Hobbyjp,
Here is a bunch of info for the Rochester Carburetors prior to 1960. There is some info about the Model "BC"s.
Cheers,
Keith
Old Online Chevy Manuals
hobbyjp
Reg: 12-25-05
01-12-06 09:11 AM - Post#851482
    In response to khardy
None of the Rochester BC's that I have seen have this type of electrical connection. I think I will just find an original carb and use it.
Execution time: 1.432 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:09 PM
