Username Post: spark plug wire stripping / crimping        (Topic#105294)
salazar44
salazar44
Loc: los angeles, ca
Reg: 04-18-05
06-28-05 08:59 AM - Post#728735
I was wondering what is a good method of stripping and crimping spark plug wires. I cannot find any strippers or crimpers at my local auto parts stores.
I was also wondering if it is okay to use 7.5mm accel wires for HEI?
my last question... what is better Ford or Chevy?
Thanks,
Vic
VIC One Repair Leads to Another! My 65 Chevy C-10 Blog
Robert_May
Old as Dirt Member
Loc: San Marcos, CA USA
Reg: 01-03-02
Re: spark plug wire stripping / crimping
06-28-05 09:56 AM - Post#728736
    In response to salazar44
I've always used a knife to do the stripping, Depending upon the particular plug wire, I either strip back enough to bring the center conductor around to the side of the wire and bend it over for almost the full length of the crimping area.
Put the terminal on so that the wire is on the center area furthest from the opening of the crimp and then use pliers (channellocks are best) and crimp the sides of the crimpong area over. There are crimpers for some of the terminals that will roll the edges of the crimp over so that the ends of the crimp dig into the wire and that is the best.
You also want to make the crimp so that it is pretty much round for best effect.
Robert May Fat? Eat less and you will get thinner!
hotwheels57
hotwheels57
Reg: 11-20-02
06-28-05 10:35 AM - Post#728737
If you need another excuse for a neat tool, look no further than SUMMIT RACING. They have their in house brand as well as a MSD brand crimping tool. It strips the insulator in one part of the die, then crimps the metal connector to the wire with the correct tension for a factory type crimp. One is slightly cheaper than the other. It's one of those tools that you wonder how you ever did without it.
SUM-900400 $39.95
Estimated Ship Date: Today
Suggested Parts Show All
Brand: Summit
Product Line: Summit Wire Crimping Tools
Maximum Spark Plug Wire Diameter (mm): 8.5
Handheld: Yes
Vise Mount: No
Ratcheting Type: Yes
Crimps Wire: Yes
Crimps Spark Plug Wires: Yes
Cuts Wire: No
Crimping Tool Material: Steel
Crimping Tool Finish: Black oxide
Crimping Tool Handle Material: Plastic
Crimping Tool Handle Color: Blue
Quantity: Sold individually.
Wire Crimping Tool, Steel, Cushion Handle, Adjustable Ratchet Mechanism,Removable Crimping/Stripping Jaws,Each
The perfect tool for crimping.
These Summit wire crimping tools are designed for spark plug wires and custom wiring applications. They give you perfect crimps every time, and include the crimping/stripping jaws for spark plug terminals. Other interchangeable dies are available separately.
The SUMMIT brand tool is $39.95 and the MSD version is $51.95. Or you can use a sharp edge, cut the insulator and crimp the connectors on with a pair of pliers. I can almost guarantee you'll ruin several connector or they'll fall off.
Karma is the universal equalizer. The Ignore User feature comes in a close second.
RickWI
Loc: Madison, WI
Reg: 10-08-01
06-28-05 11:50 AM - Post#728738
    In response to hotwheels57
Get the pliers, it will save you a sheet load of hassle.
70 SS Camaro, Dart Aluminum SmBlk 454 CI, 125 MPH (on the motor) in the quarter and 18 MPG on Power Tour
Brian McC
Loc: Salida, CA
Reg: 06-29-04
06-28-05 12:48 PM - Post#728739
    In response to RickWI
These are what I bought.
MSD Pro Crimp Tools
Worth every penny.
hotwheels57
hotwheels57
Reg: 11-20-02
06-28-05 01:51 PM - Post#728740
    In response to Brian McC
Brian, you bought a good tool, but I suspect that MSD manufactures them for SUMMIT RACING and changes the grip color so they can sell them for less. Either way, it's a great tool. My regular insulated electrical connector crimpers are the same design and I would never go back to the old style that bends with age.
Brian McC
Loc: Salida, CA
Reg: 06-29-04
06-29-05 01:50 AM - Post#728741
JW, your probably right, but without being able to hold them both in my hands I wasn't going to take the chance. I had already seen a pair of the MSD's and really liked them.
Brian
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
06-29-05 05:22 AM - Post#728742
I have a pair of the MSD crimpers with the replaceable dies, and I really like them. I have had to do a lot of electronics work in the past, and the cheapo tools give you nothing but grief. Electronics supply stores have lots of specialized tools for crimping different connections, and by comparison the MSD tool is very cheap. Some of the electronics tools can cost $200-$300 dollars, and don't come with extra dies available. When the dies are available, they are $50 and up. You are really getting a very good tool with the MSD, the tool and the dies are high quality and relatively low cost.
Am I saying you can't get by with the cheapo tools? Absolutely not. I have done it myself during the lean times, but I never want to do it again. As you get older you have less tolerance for cheap tools, especially if you use them a lot. You just want things to work properly so that you have less frustration in your life.
70sTrucker
Loc: Tehachapi, CA
Reg: 06-18-04
06-29-05 06:54 PM - Post#728743
    In response to Vaughn
I just saw the same crimpers (MSD) but with yellow handles with replacement dies for $24.99 at Autozone.... Go figure
hotwheels57
hotwheels57
Reg: 11-20-02
06-30-05 04:39 AM - Post#728744
    In response to 70sTrucker
Those are the same design as the MSD, but possibly made offshore, hence the lower cost. They could also be the insulated terminal crimper rather than a spark plug terminal crimper...that's where I got my insulated terminal crimper with yellow handle.
Execution time: 0.6 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:21 AM
