Username Post: 454 Leaky Rear Freeze Plug        (Topic#165647)
MustangDon
Loc: Mustang, Oklahoma USA
Reg: 10-07-03
07-26-07 06:45 AM - Post#1217069
Hello All,
I have a leaky rear freeze plug in my 454 engine. How can I remove it without knocking it inside the block?
Thanks,
57 Chevy 305/PG
79 Grand Prix 4 speed
86 Vet Conv.
93 Cad Fleetwood
94 Z28 468 BBC/700R4
99 Cad ETC
06 Cad DTS
07 GMC 2500HD Duramax
CDAUSA
Needs to Get Out More Member
Loc: Texas Panhandle
Reg: 12-31-01
07-26-07 07:16 AM - Post#1217091
    In response to MustangDon
Rear? As in the flywheel area?
It's easily done, knock the plug in on one side, it will pivot in the bore so you will see the cupped edge sticking out. Either lay a bar or large screwdriver in that cup and pry off the plug boss, it will pull right out. Or, some people clamp vise grips on the edge and hammer/wedge it out. I like the bar way alot better, if you have any kind of room
MustangDon
Reg: 10-07-03
07-26-07 07:24 AM - Post#1217093
    In response to CDAUSA
CDAUSA,
Thanks for the information. I was just not sure how to handle it. The BBC is in my 94 Z28, but I thought this forum would have the best information on a 454. Now I got to pull the transmission to get to them. I just pulled the transmission on my truck last month for leaks. That lift and transmission jack are earning there money this summer!
Thanks again,
57 Chevy 305/PG
86 Vet Conv.
93 Cad Fleetwood
99 Cad ETC
06 Cad DTS
MustangDon
Reg: 10-07-03
07-26-07 10:29 AM - Post#1217230
CDAUSA,
I reread your reply, and yes, it is leaking from behind the engine block below the heads and intake manifold , and forward of the flexplate on the block. I can not see the freeze plug, but I do not know what else is back there that would leak radiator fluid.
57 Chevy 305/PG
86 Vet Conv.
93 Cad Fleetwood
99 Cad ETC
06 Cad DTS
Big Steve
Big Steve
Loc: Riverside, CA
Reg: 04-17-06
07-26-07 10:46 AM - Post#1217244
Do yourself a favor, and as long as you're in there replacing the one that's leaking now, replace the other one as well. If your luck is anything like mine, it will start leaking too as soon as you replace the one that's leaking now. make sure to use brass replacements.
I may be getting older but I refuse to grow up.
'99 Suburban - sold my '93 extra cab sportside
MustangDon
Reg: 10-07-03
07-26-07 01:31 PM - Post#1217339
    In response to BIGg Steve
CAtech,
Sounds like a good idea!
57 Chevy 305/PG
86 Vet Conv.
93 Cad Fleetwood
99 Cad ETC
06 Cad DTS
Big Steve
Big Steve
Loc: Riverside, CA
Reg: 04-17-06
07-26-07 01:54 PM - Post#1217354
What I've usually found works well is to tap in one dge of the plug so it pivots in the hole, then grab it with a pair of channelocks to pop it out. Even if it ends up dropping into the block, you can still usually fish it out to the point where you can grab it with Channelocks. The original plug should be steel, so if necessary you can snag it with a magnet if it falls in. Not knowing whether you have any previous experience changing freeze plugs, I will also tell you that the easiest way to drive in the new one is to find a socket that fits just inside the cup, and use that as a driver to drive the plug in. With the limited clearance in back of the engine, this will probably work OK.
Edited by CAtech on 07-26-07 01:55 PM. Reason for edit: No reason given.
MustangDon
Reg: 10-07-03
08-01-07 12:09 PM - Post#1221881
Well, I got the transmission out and the right rear freeze plug was leaking. It looked like part of the center of the plug at the ring was cracked or rusted. The center came completely out when I removed it from the block. I was able to fish it out of the block with my fingers. It was a brass one, so maybe it was damaged upon installation! Is there any sealant to use upon reinstallation?
Thanks,
57 Chevy 305/PG
86 Vet Conv.
93 Cad Fleetwood
99 Cad ETC
06 Cad DTS
CDAUSA
Reg: 12-31-01
08-01-07 12:33 PM - Post#1221896
I always just put enough silicone on there so you know it (bore) has some, drive it in. I have a good sized 1 1/8" socket that just fits the ID, and a broken extension that I use as a driver. (Socket is turned around backwards)
If your other one looks OK, and is brass, doesn't have that ring where someone must have used a bad tool, I think I would leave it.
MustangDon
Reg: 10-07-03
08-01-07 12:43 PM - Post#1221904
Thanks for the information, Don
57 Chevy 305/PG
86 Vet Conv.
93 Cad Fleetwood
99 Cad ETC
06 Cad DTS
CDAUSA
Reg: 12-31-01
08-01-07 12:49 PM - Post#1221909
I blew by Mustang last weekend, I waved when I went by, didja see me?
MustangDon
Reg: 10-07-03
08-01-07 01:30 PM - Post#1221929
I miss ya! I was down south in Marlow this weekend with the wife's family reunion. Had way to much fun with her side of the family! All of the eating and drinking is tuff on an ole guy!
57 Chevy 305/PG
86 Vet Conv.
93 Cad Fleetwood
99 Cad ETC
06 Cad DTS
CDAUSA
Reg: 12-31-01
08-01-07 01:39 PM - Post#1221937
Too damned humid over there
Execution time: 0.238 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:05 AM
