Back to Post
Username Post: 91 5.7L TBI Timing procedures?
fishngame1
Posts 33
02-29-08 04:58 AM - Post#1377209
I have a chilton manual on my 91 GMC Sierra 5.7L TBI and it doesn't give me much info on timing procedures. I just put a crate engine in this truck, followed the procedures on installing the distributer properly, and got the engine running. I haven't took it out on the road yet to test it. Put the timing light on it and it's set at O degrees right now. I saw in a past timimg subject that a guy had to pull a wire off of the ECM when timing?? Can someone give me a little more info on which wire/wires to pull off and where? I believe I found the ECM behind the glove box. Is it a silver box with two wire harnesses connected to the front of it?
Fishngame1 - 1991 GMC Sierra 1500 4x4 Ext cab 5.7L TBI/Auto
The_Hunter
Posts 986
The_Hunter
02-29-08 06:52 AM - Post#1377244
The brown wire connector on your truck should be near where the main engine harness goes into the cab, on mine it's about 12 inches away. It can be hidden inside the loom.
Almost when timing your truck should be warmed up and running in closed loop before disconnecting the timing wire.
86 C10 Short Box
Computers are like air conditioners - They can't do their job properly if you open windows.
Chevytech
Posts 3747
Chevytech
02-29-08 08:45 AM - Post#1377340
To set the timing you must unplug the set timing connector, which is a single Tan wire with a black stripe/tracer on it. On some years the set timing wire is tan with a white stripe/tracer.
For your 1991:
The set timing wire is located, under the hood, on the main harness that goes from the engine to the firewall, on the passenger side, sometimes underneath the black plastic cover (if it’s still there) that covers the junction block, relays & fuses. It’s near the top usually on the back side of the harness. Doing this will set a code 42 in the computer. Clear the code after you are done checking or setting the timing.
fishngame1
Posts 33
03-01-08 09:32 PM - Post#1378420
Thanks! I found the wire and got the timing set. Runs great!
Execution time: 0.769 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:00 PM
