Back to Post
Username Post: Narrowed C4 suspension with Viper differential
gene
Posts 732
gene
10-12-06 11:31 AM - Post#1017073
Here are some progress pictures of the Viper differential assembled with narrowed Corvette style rear suspension in the stainless steel chassis. The half shafts, tie rods, and camber bars are fabricated new. The half shafts are aluminum, the tie rods aluminum with stainless heims, and the camber bars stainless tubing with stainless heims.
We should be assembling the rear knuckles and spindles shortly. Trusting that it should work out to a 58 inch wheel mounting face width.
C4 Corvette narrowed front/rear suspension, C5 13" calipers/rotors adapted to C4, Viper differential with Intrax 3.54 ratio (the snake has been charmed!), stainless tubular frame, LS1 with T-56, chambered exhaust side pipes
Kim57
Posts 546
10-12-06 11:57 AM - Post#1017074
Thats realy cool looking!
chevynut
Posts 11073
chevynut
10-12-06 12:07 PM - Post#1017075
Gene, that's pretty darn cool!
I had a few questions for you out of curiosity.....will the Viper Dana 44 accept the Corvette Dana 44 side yokes? I thought the Viper setup was different with a slip yoke and CV joints. Are you using the Corvette "dogbones"? How did you account for the toe adjuster plate thickness in the differential? Are you going with coilovers or air ride?
Nice work!
'56 Nomad, C4 Vette F&R suspension, Ramjet 502, Viper T56 6 speed See My Nomad Build
'56 BelAir 2DR Sedan in waiting
'01 Porsche Boxster S
'03 Chevy Silverado 2500HD 4x4 Duramax
gene
Posts 732
gene
10-12-06 12:23 PM - Post#1017076
Nice work!
I think perhaps through 2001 the Viper had similar side yokes. In 2002 or 2003 they went to constant velocity joints.
I've already polished the dog bones, so I'll probably use them.
In accounting of the toe adjustor plate, do you mean the orginal Corvette toe adjustor plate, or the one we fabricated? The fabricated one is more in line with the actual mounting at the knuckle. Should have less bump steer due to location and assigned pivot point.
I have purchased some coil overs, but am considering some factory style air suspension units rather than aftermarket. How compliant are the aftermarket units? The few I've ridden in are extremely stiff, they may not have been set up properly.
We had a Lincoln Mark in the 80's with air suspension that rode better than the recent model Lexus (should note this one didn't have air suspension, though available).
chevynut
Posts 11073
chevynut
10-12-06 12:29 PM - Post#1017077
I see that the plate is sandwiched between the differential housing and the batwing. I thought the batwing had some sort of bearing supports in it, and by spacing it back you defeated those. Are they there in the Viper version?
gene
Posts 732
gene
10-12-06 12:38 PM - Post#1017078
You are indeed correct that the Viper rear differential cover has bearing block supports for the carrier. However, in spacing it (the cover) back, we did not defeat the supports, but maintained them by sustaining them. Good question.
Posts 27334
10-12-06 01:15 PM - Post#1017079
Gene nice work, everybody likes shiny stuff, but obviously you've put more into it than just shiny.
3 dog ride
Posts 667
10-12-06 02:08 PM - Post#1017080
amazing work. it will be shame to cover it up with a body. simply super and to cool for words.
www.picturetrail.com/gallery/view?p=999&gid=8803479&vid=4204300&members=1
chevynut
Posts 11073
chevynut
10-12-06 02:13 PM - Post#1017081
Gene, did you end up making any geometry adjustments with the lower strut rod to account for narrowing the suspension? Sounds like you lost about 5 1/2" in width.
busyguy8
Posts 5667
busyguy8
10-12-06 04:25 PM - Post#1017082
Gene,
That is just absolutely jaw dropping...
Aquired a '56 2dr hdtp BelAir on 6/9/05!
Link to my pics!
-bill
gene
Posts 732
gene
10-13-06 04:33 AM - Post#1017083
Yes. The strut rod inboard pivot was lowered and moved forward. Decreasing those two angles after moving the knuckle inward.
Lost approx. 4-1/2" from the early C4 model wheel mounting width.
diognes56
Posts 461
diognes56
10-13-06 05:36 AM - Post#1017084
Shiney! :drool:
David
-----Let them hate, so long as they also fear.-----
gene
Posts 732
gene
10-20-06 09:33 AM - Post#1017085
The assembly is progressing farther. Here are some photos of the rear knuckles, C5 brake adapters, Porsche Turbo rotors, assembled to the camber bars, 4 link, and half shafts.
awsum55
Posts 8856
awsum55
10-20-06 04:50 PM - Post#1017086
I always thought that rotors needed to be installed so that the cooling fins faced forward to catch air. Am I misinformed, or is that designed that way for a reason?
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die
chevynut
Posts 11073
chevynut
10-20-06 05:47 PM - Post#1017087
Gene, that sure is looking "sick". Coupla more questions....why the Porsche rotors? Wouldn't Wilwood or Baer do the job and be less expensive? What are you planning to do for an e-brake?
John, the rotors are designed to pull air from the center and throw it out toward the wheel for cooling. Mine are installed the way Baer labeled them and they're that way:
HYPR
Posts 10669
HYPR
10-20-06 08:44 PM - Post#1017088
I'm impressed as usual, some pretty trick stuff there Gene!
Bob
Execution time: 5.344 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:25 AM
